need info on ticking noise please - Kia Forum
 2Likes
  • 2 Post By MIA KIA 09
post #1 of 3 (permalink) Old 07-09-2018, 09:21 PM Thread Starter
Drives: 2009 kia borrego
Red face need info on ticking noise please
purchased a Borrego v6 4wd with 67000 on it and have a slight rattle when first fired up and it also has a ticking noise that's really noticeable when in gear for about 3 or 4 mins ,sounds like a lifter but I read that kia had an issue with timing chain adjusters , any info would be appricated
vehicle runs great and I changed the oil to synthetic mobile one 5 w 20
my history with this vehicle purchased vehicle jan 2018
purchased this veh at myrtle beach Chrysler jeep which is owned by bobby gail kia and got taken to the cleaners they stated it had a 128 point inspection and was in tip top shape ,,,,1200 miles was getting a brake noise pulled the wheels found the brake pads were down to the metal and all guide pins were frozen up,right rear caliper was damaged , emergency brake shoes were toast and brake mount nails were missing and 2 springs were broken ,,,,I noticed that on the highway it had a slight pull to the right so I took it to the kia dealer to be aligned they came out and said it needed 1500 in front end repair ,,,, camber bolts were frozen up and ball joints were shot and 1 lower control arm needed replaced ,,,,,,,,went home set it on stands and broke all bolts loose with a 1/2 in drive ratchet ,,,,found no bad ball joints I purchased 3 kias from bobby gail in 3 years next one will come from the Toyota dealer but really like driving this vevicle
randylb2 is offline
post #2 of 3 (permalink) Old 07-10-2018, 06:26 AM
Quoted: 363 Post(s)
Sorry you have had such an experience with your ride. Yes they had a TSB about timing chain tensioners in response to your main question. BUT not much more help can be given until you complete your profile info, with year model and engine size. YOU may know what you have ...but we don't.
ron1004 and GottaCruise like this.
MIA KIA 09 is offline
post #3 of 3 (permalink) Old 07-10-2018, 08:52 AM
Drives: '96 Camry v6 XLE, '00 Camry LE
Quoted: 122 Post(s)
Greetings,
Unfortunately the "128 point inspection" is really just a selling point, to get the vehicle out of the dealership's door these days.
Excellent that you have the skills/tools/ability to properly diagnose and make repairs on the vehicle.
If the lifter noise started after the 5w20 oil change, you may want to consider using a heavier viscosity oil, to see if it quiets the lifter(s).
From the 2009 (CA) owners manual, the Borrego is rated for / ok to use 5w30 weight oil, in the v6 motors.
* If doing any kind of equipment hauling and/or towing with the vehicle, I would be using 5w30 weight oil in the motor.
If the noise only appears on cold startup / is not constant, another possibility may be an EGR modulating or other emissions control valve, providing cold-start assistance.. I would also be checking that, if here.
Link to 2009 Borrego owners manual: (pg 419)
https://www.kia.ca/content/ownership..._Manual_EN.pdf
Hope the rattle and noise issues turn out to be minor.
Regards, GottaCruise
OBD-II Codes:
GottaCruise is offline
Engine ticking noise cickos Kia Carens & Rondo Forum 22 01-28-2018 08:33 PM
How to permanently solve engine ticking noise with ONLY 10 CENT! Blkid 2G (2006 - 2011) Rio & Rio5 2 02-11-2017 11:23 AM
The Mysterious Honking Noise redsoxmk 3G 2011 - 2016 Sportage 13 07-29-2015 09:27 AM
Strange ticking noise when cold. mozart999uk Cerato (2003 - 2008) & Spectra5 (2004) 14 10-01-2009 02:54 AM
Ticking noise when braking - axle shafts? JoeWag 1G (2001-2005) Rio 8 01-17-2009 09:43 PM
