Mis-fire -- please read - how to align the timing marks - Kia Forum
post #1 of 19 (permalink) Old 04-25-2018, 08:01 AM Thread Starter
Drives: 2009 kia borrego
Quoted: 9 Post(s)
Hello,
I have a 2009 Kia Borrego. At first it would idle rough, and seem like it would want to stall. So we threw it on the code reader.
-At first we had a the codes p0016 and p0018 - so we changed the cam shaft sensors. And, then we changed the spark plugs. Then we changed the ignition coils because it was giving codes misfire in one and three.
After all that now we are getting code p0026 - P0026 KIA - Intake Valve Control Solenoid Circuit Range/Performance Bank 1.
Which now when you put it in drive it's like the car wants to stall out.
Any ideas -- any at all?
Traciekay22 is offline
post #2 of 19 (permalink) Old 04-25-2018, 08:32 AM
Quoted: 672 Post(s)
Originally Posted by Traciekay22 View Post
Hello,
Most often a sensor code does not mean that the particular sensor has failed, but more likely that its signal is out of sync, such as a fouled variable valve timing (VVT) solenoid will cause a cam sensor code.
What is the mileage, the service history, when last was the oil and oil filter changed, what brand of oil filter used?
It could be sludge has fouled the cam solenoids.
ron1004 is offline
post #3 of 19 (permalink) Old 04-27-2018, 06:40 PM Thread Starter
Quoted: 9 Post(s)
The mileage is 73k
I got the oil changed and serviced at Walmart a few weeks ago, so i'm not sure of the type oil and filter they used when that happened.
post #4 of 19 (permalink) Old 04-27-2018, 06:44 PM
Quoted: 672 Post(s)
The mileage is 73k
It would be in your own interest to know what oil is used and the filter - it is common knowledge that some brands of filters are not compatible with certain Kia models.
What's the service history?
ron1004 is offline
post #5 of 19 (permalink) Old 04-27-2018, 06:47 PM Thread Starter
Quoted: 9 Post(s)
It's been serviced when needed - such as oil changed. It's been the garage when inspected - nothing was noticed. It never had any problems other than this. So, I'm not exactly sure what has caused this.
post #6 of 19 (permalink) Old 04-27-2018, 06:51 PM Thread Starter
Quoted: 9 Post(s)
the oil has been changed every 3-4k miles like suggested. We just started recently taking it to Walmart the last two times I needed the oil changed.
post #7 of 19 (permalink) Old 04-27-2018, 07:05 PM
Quoted: 672 Post(s)
Walmart and quick-lube places are notorious for errors when doing things as crucial as a oil change with filter, and with modern cars now using the engine oil for dual purpose, lubrication of bearings etc., and as hydraulic fluid for the variable valve timing actuators, it has become more critical to use the correct oil and filters, at the correct interval.
Seeing as the error codes point to valve timing issues, I'd start by getting the oil and filter replaced with the correct grade and type, and check for sludge when doing this.
ron1004 is offline
post #8 of 19 (permalink) Old 04-27-2018, 07:11 PM
Drives: 2017 AWD Sportage SX - Black / Beige
Quoted: 624 Post(s)
Walmart???....no offence but I wouldn't let Walmart put air in the tires and expect them to get it right, let alone anything else.
What ron1004 said
Sloppy is offline
post #9 of 19 (permalink) Old 04-29-2018, 01:52 PM Thread Starter
Quoted: 9 Post(s)
Misfire in 1-3-5
It has a mistake fire in 1-3-5.
When you put it in drive it likes it wants to stall out.
Any ideas what to check for?
Last edited by ron1004; 04-29-2018 at 04:06 PM. Reason: Duplicate threads and posts merged and moved to model specific section - no cross posting
post #10 of 19 (permalink) Old 05-03-2018, 08:31 PM Thread Starter
Quoted: 9 Post(s)
Timing - please read. Please
How do you time a 2008 Kia Borrego 3.8 V6?!
And do you need any special tools.
DIY Timing Belt - WARNING Interference Engine - Service Interval Raven1210 1G (2001-2005) Rio 104 06-04-2016 05:53 PM
Kia Spectra 2litre DOHC gas - TIMING CHAIN MARKS Peter Brooks Kia Cerato, Shuma & Spectra Forum 0 12-08-2015 10:12 PM
Timing belt and timing marks determinedmom1 Shuma & Spectra (1997-2003) 0 05-19-2015 07:54 PM
Timing Belt Rio 2001 to 2005 Raven1210 Do it Yourself 6 02-19-2012 09:34 PM
How to Replace Timing Belt Raven1210 2G (2006 - 2011) Rio & Rio5 1 05-27-2009 12:16 AM
