-   Kia Mohave & Borrego (https://www.kia-forums.com/kia-mohave-borrego/)
-   -   ALL Warning lights on (https://www.kia-forums.com/kia-mohave-borrego/237410-all-warning-lights.html)
cnaimo 04-20-2016 06:55 PM
Hi i seem to be having the same issue with my 2009 EX and started to act up . Warning lights on, sometimes doesn't let me shift back to park, Dealer says it is a CAN error.
Waiting on new brake light switch.
have you had the problem come back?
ALL Warning lights on, Sometimes doesn't let me shift back to park, Dealer says it is a CAN communication error.
Had recall done a few years back
Any thoughts , Advice
thank you in advance.
ron1004 04-20-2016 07:10 PM
Let us know if the brake light switch resolves your problem.
Please update your profile detail, ......at least location and vehicle.
ron1004 04-25-2016 07:39 AM
Did you receive the brake light switch, and if so, did it help?
cnaimo 04-25-2016 08:47 AM
Just got the part going to try it today ..
thanks
longironjake 05-02-2016 08:08 AM
All warning lights on
After Kia replaced the rear brake light switch a second time under their warranty recall last year, the problem as you described has not returned. It did return after the first rear brake light switch replacement. If your 2009 Borrego did not get the rear brake light switch recall, check with your Kia dealer for recall replacement.
cnaimo 05-11-2016 08:54 PM
Lights fixed
Well the second brake switch did nothing .. it ended up being a bad ABS module apparently the CAN bus went thru the ABS and it made everything fail.
Charlie
