check engine light is on... - Kia Forum
post #1 of 4 (permalink) Old 02-18-2015, 07:22 PM Thread Starter
Drives: 2009 Kia Borrego
Quoted: 5 Post(s)
Hi
Yesterday the check engine light came on in my 2009 Borrego
and tonight, it turned off
I checked it both this morning and after the check engine light
went out tonight and with both tests my code reader gave me
the following codes:
$7E8: Engine - 5 codes
P0171 $07E8
1/5 Generic System too Lean Bank 1
2/5 B Camshaft position timing over retarded Bank 1
3/5 B Camshaft position timing over retarded Bank 2
4/5 System too lean Bank 1
5/5 B Camshaft position timing over advanced or system performance
Bank 1
$7E9: A/T - 1 code
Can anyone on this forum tell what is wrong with my Borrego and if
this is a typical issue?
Japper is offline
post #2 of 4 (permalink) Old 02-19-2015, 11:33 AM
Drives: 09 Borrego EX V8 2WD
Quoted: 3 Post(s)
Took this from my service manual.
Camshaft_Position.pdf
HavasuPaPa is offline
post #3 of 4 (permalink) Old 02-20-2015, 05:06 AM Thread Starter
Quoted: 5 Post(s)
Thanks HavasuPaPa
If I understand this correctly I just have to drive the car until the condition
clears itself; is this your interpretation also?
Not sure what the DTC is but I am guessing that this is something associated with the
KIA scantool...
The check engine light on my dash is no longer lit and all I have is a generic scantool
that might not display DTC Readiness flags. Should I just clear these with my scantool?
Thanks again
Japper is offline
post #4 of 4 (permalink) Old 02-20-2015, 09:21 AM
Quoted: 3 Post(s)
DTC (Diagnostic Trouble Codes). Your scan tool should read the codes the same as a Kia tool. I only sent the information so you can see what components may be causing the codes to appear. As you said, try the driving cycles they suggest:
Accelerate and decelerate more than 10 times within 5 minutes. Repeat a second time.
poor running + stalling + check engine light opirus2005 1G Kia Amanti & Opirus Forum 5 08-06-2015 08:42 AM
check engine light hotrodhenson Kia Cerato, Shuma & Spectra Forum 5 06-03-2009 09:06 PM
3 week old Kia Rio 2009 - check engine light Janye 2G (2006 - 2011) Rio & Rio5 14 04-07-2009 05:51 PM
Flashing O/D + Check Engine Light kiaSephiaUser2008 2G (1998 - 2001) Sephia 2 02-25-2008 09:22 PM
