Aftermarket Radio Installation - Antenna Connection - Kia Forum
post #1 of 5 (permalink) Old 03-13-2014, 09:15 AM Thread Starter
Drives: 2009 Kia Borrego, LX
I have a 2009 Borrego EX (8cylinder) that had the Infinity 10 speaker system with Sat. I have replaced all the speakers, installed multiple amplifiers and installed my new Kenwood receiver. The issue that I am having is that I am UNABLE to get a AM/FM signal to the receiver. I can stream music from my iPhone to the system with great results and I have been using this method since last fall. Now that spring is on the horizon I would like to resolve this issue.
I would like to obtain a schematic that indicates what each of the connectors are that came from the back of the OEM radio (not the wiring harnesses) but the two plug in connectors. I don't have an nav or back up camera (yet) but the oem radio did have aux/usb on the console. There is a SAT antenna on the back roof and I am unsure where the antenna is located (rear windshield maybe)? The OEM radio had of course AM/FM/SAT working when I purchased the car but I think I have overlooked something when I installed the Kenwood. I have connected the blue wires (from the OEM harness to the AFM radio harness) and have purchased a metra 40-Ki10 connection to adapt the AFM radio to the OEM antenna. The OEM antenna connection has two wires feeding the connector but the metra connector only has one plug exiting the connector and this is the male RCA type plug that plugs directly to the Kenwood radio. I am thinking that my issue is with this connection somehow.
Any suggestions, comments, thoughts would be appreciated. Thank you
mtbikerejg is offline
post #2 of 5 (permalink) Old 03-13-2014, 03:42 PM
Drives: 09 Borrego EX V8 2WD
Quoted: 3 Post(s)
This might help.
HavasuPaPa is offline
post #3 of 5 (permalink) Old 03-18-2014, 10:38 AM Thread Starter
This is an awesome all in one document. While I found sections of this document on METRA and from KGIS (owners tech support), there is some additional detail here that I haven't seen before (and would have come in handy when I was removing door speakers and trim panels to replace the OEM subwoofer)..Thank you for taking the time to locate this document (or put it together) although specifically this doesn't address my specific issue which is the antenna connection (all the diagrams show one wire feeding the connector) and my connection has two...
Regardless, thank you for the attachment, I have saved this for future reference. Its much appreciated..
post #4 of 5 (permalink) Old 07-14-2014, 11:19 AM
Hi there,
I have there same issue with the antenna connection, no AM but FM works fine. one of the antennas is located in the rear passenger side window, the roof antenna is apparently dual, GPS AM/FM.
It appears that the factory AM/FM antenna has two cables, the original KIA head unit has one connector but with both cables going into it and as you have already stated the Metra antenna adapter apparently uses only one of the two original cables. Maybe that's where we are having difficulty.
Your thoughts and good luck.
manxman is offline
post #5 of 5 (permalink) Old 09-01-2014, 09:48 AM
Were you ever able to get a definite answer on the two versus one antenna connection?
I did some investigating on my Borrego LX antenna. took things apart, one antenna cable comes from the roof antenna (the other is Sirius and completely different) and the other comers from the antenna mounted in the rear passenger side window, The roof antenna has a power connection.
manxman is offline
radio antenna problem vroomvroom 2003-2010 Sorento Forum 1 05-18-2016 07:42 AM
Aftermarket radio Daniel Negron 2G (2003-2010) Sportage 2 08-05-2015 02:53 PM
Aftermarket Radio - Any Luck? gumbyjunior1 Kia Forte/Cerato (TD) and Koup Discussion Forum 7 10-05-2009 06:38 PM
Radio antenna in rear window problems N106FM Kia Magentis & Optima Forum 0 06-22-2007 08:06 PM
Aftermarket Radio in 03 Spectra LX Fixxxer Shuma & Spectra (1997-2003) 2 08-27-2006 09:50 AM
