2001 Kia Optima (Automatic) Transmission Problem...Ideas? - Page 3 - Kia Forum
post #21 of 37 (permalink) Old 06-10-2008, 09:50 PM
I'm having a similar problem
I have an 03 Spectra w/ automatic transmission.
In the past I've had symptoms familiar to these, although when I had problems, all I had to do was stop and restart the car. Recently, I was on the freeway and my car seemed to shift into neutral. I could shift the stick but the gear wouldn't change. My engine sounded like there was some extra noise too. Could it be these sensors, could it be the timing belt, or does it sound more like my transmission has failed?
ncwolfe is offline
post #22 of 37 (permalink) Old 01-29-2009, 09:07 AM
Just go this car recently. When in traffic and my foot is on brake pedal while gear is on D, I start hearing this sound as if someone is hiting the booth. But when I put it on Neutral, the sound stops. It progressed to really jerking in traffic, so I took it to the garage for repairs. Collected it a week ago and problem has started again
brym! is offline
post #23 of 37 (permalink) Old 05-29-2009, 09:27 AM
Originally Posted by Brian Lewis View Post
I to am having the exact same problem on my 2001 Optima V6! Are these sensors designed to go out? I had a sensor replaced a couple of years ago and now the same problem again.
hey brian, how much did it cost for dealer to replace sensors?
kiaopse is offline
post #24 of 37 (permalink) Old 06-25-2009, 11:00 AM
Traveldude189's Avatar
Drives: 2001 Kia Optima SE V6, 1994 Olds Cutlass Ciera S, 1987 Ford Bronco
Send a message via AIM to Traveldude189 Send a message via Yahoo to Traveldude189
yeah i had this happen too, actually it was the speed control sensor in mine, it happened a few weeks ago, which then the place says you need a new raditor, yay another 700 bucks in the kia since janurary, and guess what on monday the frame failed from the recall and now its in the garage till friday, getting 6k dollars worth of work kia is paying for its about time
Traveldude189 is offline
post #25 of 37 (permalink) Old 07-30-2009, 08:41 AM
2001 Kia Optima Automatic Trans Shift Problems
I realize this is an old forum, but maybe we can get it started again. I am having the same problem...a hard shift and then it won't shift out of 3rd gear. I tried to look for the input/output speed sensors online with no luck.
Did replacing the sensors fix the problem for anyone? Also, any ideas where I can find the parts?
diggity is offline
post #26 of 37 (permalink) Old 08-10-2009, 08:46 PM
IZZYG530's Avatar
Sensor or Transmission??
I'm having the same jerking motion with 2001 kia optima 2.4L 4cyl. changed one "speed sensor" already but kia still loses pedal power, of course after a few herky jerky movements from the car. it loses its get-up and go. When at a stop sign after car has herky jerked, car doesn't want to go car slowly accelerates even if pedal is to the korean metal. If i turn car off then back on problem resolves itself till next time it herky jerks again can anyone help me make the right decision on wether to change other speed sensor or have transmission check. Also not sure if transmission pulse generators are the same thing as speed sensors. would appreciate any usefull knowledge on this apperantly frequent problem..
IZZYG530 is offline
post #27 of 37 (permalink) Old 09-09-2009, 03:02 PM
same as it ever was
trans fluid changed, both sensors changed(I/O), timing belt changed, camshaft sensor changed. Result lots of money spent and the trans issue is the same as everyone else runs for a while and shifts into 3rd stop and restart and you are good to go for a few more miles. Now a new issue after the camshaft sensor replacement the car runs for about 10-15 miles them quits till its sits for a while 30min or so then will do the same thing..Man if someone out there has an answer you would be an answer from god. I know the old get rid of it but I still owe on it as I bought it used and still owe on it and dont want more of a payment from trading it in..
wtrout is offline
post #28 of 37 (permalink) Old 10-24-2009, 02:22 PM
my 02 kia optima v-6SE
is doing the same thing
goes from 4th to 3rd like being rearended
i had the sensors replaced around 650.00
then 2 weeks later check engine light on again
took it back and sensores out
had shop redo the sensors along with a few choice words and again check light on and shows sensor or and something like turbine speedsensor now
along with now im getting the flickering dashpanel lights along with headlights and overhead lights
when i apply brakes the entire light system goes very dim then returns to normal then flickering begins.
this is my last optima i buy.
KIAOPTIMAMAN is offline
post #29 of 37 (permalink) Old 10-24-2009, 03:17 PM
I had the same problem with my Magentis which is the Canadian version of the Optima. The transmission had 55,000 kms on it and had to be replaced under warranty. The new transmission does exactly the same thing. Kia would only allow the balance of the warranty on the new transmission and dragged their feet until the warranty was up. Each time I took the car in for transmission service under warranty they drained the oil out of the car and sent me on my way. I was stranded in a snow storm in a desolate area with my disabled spouse when the oil light came on after just such a Kia service visit. Fortunately a snow plow driver came by and put some oil in the car. Unfortunately the car still didn't run right and he kindly drove us home in his truck. Not fun when you are a senior and need a reliable car.
Baglady is offline
post #30 of 37 (permalink) Old 12-25-2009, 08:14 AM
having problem with "D" drive
any one have idea,
my kia sefia 2001 had a problem of "D" drive gear No.1 i can't move with "D" i've to use gear No.2 moving then when reach 40km shift to D will picks-up low than 40km gear fail.
any idea will be much appreciated.
thanks Cooldin
cooldin78 is offline
Optima 2008 LX I4 OS - where is transmission oil filter? Ameisen 3G (2006.5+) Magentis & Optima 1 07-31-2017 06:46 PM
cold start problem 2001 sportage reginald 1G (1993 - 2002) Sportage 1 07-10-2009 10:06 PM
2001 optima refueling problem firsttimefixit New Member Area/Introduction 0 02-14-2009 09:24 AM
European Carnival diesel and automatic transmission svindler Kia Carnival & Sedona 2006+ 2 10-29-2006 03:38 PM
