2004 kia optima - runs 5 minutes, then dies - Page 2 - Kia Forum
post #11 of 15 (permalink) Old 10-09-2009, 05:43 PM
This happened to me after replacing the timing belt. A week later it was running way ruff, timing wasn't set right. stilll would run ruff after it was fixed. they tested the Crank and CAM sensors and they tested good in the off position. I had the shop replace the crank sensor anyways (they refused to beleave me that a sensor can be bad at zero RPM). A week after that it would start and run for 15 seconds and shut off. Well round two started with arguing with the mechanics and them insisting a sensor can't be bad at zero RPM. So i went and bought one myself and put it in in front of them. Low and behold the car started up and ran fine.
NorthIdaho is offline
post #12 of 15 (permalink) Old 01-06-2011, 10:47 PM
I have a 2004 kia optima with a 2.4 engine and automatic transmission. it will not start or starts and stalls instantly. it has a new fuel pump,coils,plugs and ecm. i have determined that cylinder 3 and 4 have hot wire to injector but the pulse signal wire only pulses 1 time when you first turn the key over. cylinder 1 and 2 pulses as they should. After i found this i replaced ecm and injector wiring harness. still same thing any help would be apprieciated! Thank you
psmith4131 is offline
post #13 of 15 (permalink) Old 01-07-2011, 10:05 PM
hows the timing belt?
2004 Optima 2.4 LX auto ( original owner )
amave2008 is offline
post #14 of 15 (permalink) Old 01-08-2011, 11:19 AM
Drives: 2010 SOUL + & 2003 OPTIMA NOW, I HAVE OWNED 5 OTHER KIAS
Your Optima does not have an external filter, the owners manual on my 03 says it has one but it doesn't. It just has a tank filter, but the filter doesn't sound like the problem. Does it have a check engine light on?
RENAULTMAN is offline
post #15 of 15 (permalink) Old 12-07-2014, 08:03 PM
So I have the same problem as "kimsquilts" but the fact that my battery seems to have trouble getting enough power to the engine (even after letting it sit for a while). Does anyone suppose this could be a wire harness problem?
Birdie_B is offline
2004 Kia Optima 2.4 Dies Randomly (Not Crank Shaft Sensor) Gobind05 Kia Magentis & Optima Forum 0 09-16-2009 05:29 AM
Kia Optima 2004 2.4l suddenly dies while driving nx3xo Kia Magentis & Optima Forum 7 09-14-2009 12:07 AM
2001 Kia Optima runs fine then rough idle and dies billym8228 1G/2G (2001-2006) Magentis & Optima 9 06-17-2008 11:10 AM
Update - 04 Optima runs then dies - ?crankshaft position sensor kimsquilts Kia Magentis & Optima Forum 6 02-05-2008 03:21 PM
