Please help with misfire - Kia Forum
post #1 of 11 (permalink) Old 10-18-2014, 06:49 PM Thread Starter
I have a 2001 Kia Optima 2.4 L V6 misfire #6 I then replaced the spark plugs and wires and fuel filter. Again misfire #6 I took it into Amco to test the compression and the coils said they were both good. CEL was reset and still misfiring. Moved fuel injector #6 to the #4 position hoping the check engine light would come on say #4 misfire and all I would have to do was replace the fuel injector. Still no check engine light and it still misfiring. screwdriver to the fuel injectors they all sound like they're firing off I'm lost and don't know what to do
Alexmann is offline
post #2 of 11 (permalink) Old 10-19-2014, 12:10 AM
Drives: Subaru WRX
Quoted: 47 Post(s)
if you have fuel and spark then there has to be an issue with the cylinder. What were the results of your compression test dry, wet, and running?
Kiatechkyle is offline
post #3 of 11 (permalink) Old 10-19-2014, 01:13 AM
Drives: 2014 Sportage LX AWD, 2014 Forte LX+
Quoted: 59 Post(s)
There are only so many things that can go wrong:
- spark
- compression
- fuel
- air
Go with free/cheap to check first.
Ceezer is offline
post #4 of 11 (permalink) Old 10-19-2014, 10:29 AM Thread Starter
As per aamco compression was "at factory specs" I forgot what they had told me but he said it ruled out head gasket, valves an piston rings. I've still been waiting for the CEL to come on but nothing, last night I checked the fuel pressure regulator. I read a post on here saying they had a similar problem where gasoline was leaking into intake and that was causing a misfire -0- gas found in the vacume hose. I'm at a complete loss. If it was timing wouldn't that cause a misfire on all cylinders and not just one. Same with coil if coil was going because two are on one coil wouldn't another cylinder be misfiring. Seems like I'll never get to the end of this
Alexmann is offline
post #5 of 11 (permalink) Old 10-19-2014, 10:44 AM Thread Starter
Here is an attached picture of my engine
Alexmann is offline
post #6 of 11 (permalink) Old 10-28-2014, 10:02 PM
Same nightmare! 2.7L
If you figure this out, please let me know. If I figure it out, I will definately PM you. I have the exact same problem. Misfire on #6 , then sometimes on #2 , and sometimes on #4 . These are all on bank 2 (same side on the front of motor).
Replaced all coils, plugs, and all 4 O2 sensors. Spent a fricken fortune so far!
I checked and tested OCV (oil control valves). I could only remove bank 2 OCV to check for any debris or clogging. It was clear and OHM resistance was within specs. I wasn't able to remove Bank 1 OCV because you have dismantle the hell out of the motor to pull it out. But, I was able to measure its resistance; which was also within specs.
I test TPS resistance; again it was within specs.
Here is my Freeze Frame data when the misfire comes back. if anyone wants to look:
Freeze Frame
Fuel System 1 OL-Fault
Fuel System 2 N/A
Calc Load (%) 53.7
ECT (degrees C) 79
STFT B1 (%) 0
LTFT B1 (%) -0.8
STFT B2 (%) 0
LTFT B2 (%) -0.8
MAP (kPa) 65
Eng RPM 1880
Veh Speed (km/h) 83
Spark Adv (degrees) 23.5
IAT (degrees C) 8
MAF (g/s) 24.67
TPS (%) 25.1
Run Time (Sec) 1309
Command EVAP (%) 5.1
Fuel Level (%) 49
BARO (kPa) 92
ECU Volts (V) 14.25
LOAD Value (%) 50.2
EQ Ratio 1.001
Rel TPS (%) 16.1
TPS B (%) 25.1
ACC Pedal D (%) 24.3
ACC Pedal E (%) 12.2
Command TAC (%) 21.6
Tubig is offline
post #7 of 11 (permalink) Old 10-29-2014, 01:16 PM
Drives: 2002 Kia Optima 2.7 SE V6
I had the same problem a while back its your ignition coil itself thats causing the misfire
Darriel Bonds is offline
post #8 of 11 (permalink) Old 10-29-2014, 06:57 PM
Thanks Darriel, but I've already replaced all 6 coils (some twice now). The problem hasn't gone away yet
Tubig is offline
post #9 of 11 (permalink) Old 10-30-2014, 12:10 PM
What about the gap on the plugs themselves i know they say they come pre gapped but i doubled checked mine when i did mine and they weren't gapped properly
post #10 of 11 (permalink) Old 10-30-2014, 12:12 PM
Constant misfire on cylinder 2 Paul88 2003-2010 Sorento Forum 7 06-11-2017 10:17 PM
2003 Kia Sorento misfire driing me nuts Radorix360 2003-2010 Sorento Forum 8 05-19-2017 06:28 AM
Kia Soul multiple misfire codes Michealwusa Kia Soul Forum 7 05-22-2015 09:14 AM
1999 Sportage misfire BG Sportage 1G (1993 - 2002) Sportage 1 12-21-2008 03:50 PM
Engine Misfire in Cylinder #3 - I am baffled erbbrian 1G (2001-2005) Rio 10 10-08-2007 02:58 PM
