2017+ Forte MPI 2.0L is it the Atkinson version? - Kia Forum
post #1 of 3 (permalink) Old 04-19-2019, 05:41 AM Thread Starter
Drives: soon getting one
Hi All..
I cant find any reference on the interwebs, but is the 2017+ Forte MPI 2.0L they are using is the same as 2017+ Hyundai 2.0L MPI Atkinson that is used in the Elantra???..
I saw the specs on Kia.ca and other website, and the output HP and torque are the same, but it does not specifically state its the Atkinson design 2.0L.
Thanks everyone!!
cb900f2 is offline
post #2 of 3 (permalink) Old 04-19-2019, 03:48 PM
SoNic67's Avatar
Drives: Kia Soul!, 2011
Quoted: 39 Post(s)
The engine itself is not "Atkison". The cycle of that engine is modified to be "Atkinson" by using a different valve timing program in the car's PCM. It's used exclusively in combination with the hybrid mode (batteries).
"The term "Atkinson cycle" began to be used to describe a modified Otto-cycle engine—in which the intake valve is held open longer than normal, allowing a reverse flow of intake air into the intake manifold. This "simulated" Atkinson cycle is most notably used in the Toyota 1NZ-FXE engine from the early Prius.
The effective compression ratio is reduced—for the time the air is escaping the cylinder freely rather than being compressed—but the expansion ratio is unchanged (i.e., the compression ratio is smaller than the expansion ratio). The goal of the modern Atkinson cycle is to make the pressure in the combustion chamber at the end of the power stroke equal to atmospheric pressure. When this occurs, all available energy has been obtained from the combustion process. For any given portion of air, the greater expansion ratio converts more energy from heat to useful mechanical energy—meaning the engine is more efficient.
The disadvantage of the four-stroke Atkinson-cycle engine versus the more common Otto-cycle engine is reduced power density. Due to a smaller portion of the compression stroke being devoted to compressing the intake air, an Atkinson-cycle engine does not take in as much air as would a similarly designed and sized Otto-cycle engine. Four-stroke engines of this type that use the same type of intake valve motion but using forced induction to make up for the loss of power density are known as Miller-cycle engines.
If demand for more power is intermittent, the power of the engine can be supplemented by an electric motor during times when more power is needed. This forms the basis of an Atkinson cycle-based hybrid electric drivetrain. These electric motors can be used independently of, or in combination with, the Atkinson-cycle engine, to provide the most efficient means of producing the desired power. This drive-train first entered production in late 1997 in the first-generation Toyota Prius. "
So it goes...
SoNic67 is offline
post #3 of 3 (permalink) Old 04-23-2019, 04:45 AM Thread Starter
Thanks SoNic67 for the info.. But doesnt address my original question.
cb900f2 is offline
  Kia Forum > KIA Models > Kia Forte/Cerato (TD) and Koup Discussion Forum
2017 Kia Forte S initial thoughts Datarock Kia Forte/Cerato (TD) and Koup Discussion Forum 0 06-10-2018 12:10 PM
KIA Forte 2017 GunnarInLA Kia Forte/Cerato (TD) and Koup Discussion Forum 1 02-27-2018 05:14 PM
2017 Kia Forté jw.finkler Kia Forte/Cerato (TD) and Koup Discussion Forum 2 08-04-2017 05:39 AM
2017 Kia Forte Test Drive: Here's What One Honda Civic Owner Said - Sponsored by Kia AutoGuide.com Kia Home Page News 0 10-28-2016 12:26 PM
K&n 33-2201 Kia Hyundai Spectra, Sportage, Tiburon MstrTec Parts For Sale / Trade 0 05-12-2009 06:26 PM
