2008 spectra will not start - Kia Forum
post #1 of 8 (permalink) Old 06-20-2019, 08:55 PM Thread Starter
Drives: 2008 Kia spectra lx
Unhappy 2008 spectra will not start
Lost belt (alt,water pump & Pwr Steering) engine overheated and not start. Replace belt, inspected TB, checked spark and compression. All okay except there is no compression on any cyl. Any suggestions?
ronestes is offline
post #2 of 8 (permalink) Old 06-21-2019, 09:54 PM Thread Starter
Number of cams
I have a 2008 kia spectra ex with that appears to have a single cam engine (not dohc). Is this possible? If so where can I get info on it?
ronestes is offline
post #3 of 8 (permalink) Old 06-22-2019, 05:24 AM
Quoted: 364 Post(s)
It only APPEARS to be a SOHC motor due to only ONE CAM GEAR PULLEY run from the timing belt. The 2.0 liter motor in your car is a DOHC, with the exhaust cam driven by a chain off the intake cam under the valve cover.
MIA KIA 09 is offline
post #4 of 8 (permalink) Old 06-22-2019, 09:07 AM
Quoted: 364 Post(s)
MOST PROBABLE that either the timing belt shed off cog teeth on the timing belt at the crank pulley and not able to spin the cam over. OR the "overheat" ruined the head. Either way you're in for major disassembly to inspect properly and determine what repairs are needed...NOTE..This is an "interference motor", meaning if timing belt goes that VALVE/valvetrain and piston damage is done.
post #5 of 8 (permalink) Old 06-22-2019, 09:11 AM
Quoted: 710 Post(s)
How did you go about the inspection of the TB?
The lack of compression could be one-, or both, TB failed or head gasket blown.
ron1004 is offline
post #6 of 8 (permalink) Old 06-22-2019, 10:16 AM Thread Starter
It appears that this engine has a TB outside and another inside the valve cover. I checked the one outside by rotating the engine while checking for lost teeth etc. Rotated engine thru a couple of cycles and noted that timing marks lined up. Will now remove valve cover for further analysis. Thanks
ronestes is offline
post #7 of 8 (permalink) Old 06-22-2019, 10:25 AM Thread Starter
Where can I get info on this engine?
ronestes is offline
post #8 of 8 (permalink) Old 06-25-2019, 10:18 AM
DavesSpectra's Avatar
Quoted: 451 Post(s)
ronestes...
Any modern engine can't handle ANY overheating... Yours probably has a blown head gasket or a warped head...
The best "repair" would be a low mileage engine from a salvage yard... Try a "pull-a-part" type yard or search "car-part.com"... You should be able to find an engine (complete) for $500 or less... Why waste money on a head or head gasket when a complete engine is so cheap...
DavesSpectra is offline
