Slow RPM drop when shifting gears - slight rough at idle - Kia Forum
post #1 of 3 (permalink) Old 02-21-2019, 09:23 AM Thread Starter
Drives: Spectra5 2006 Manual Trans
Hi, Just bought my daughter a used 2006 Spectra5 with manual transmission with about 81K miles on it so not real familiar with what is normal.
When shifting gears slowly the engine seems to hold the idle longer than I thought normal would be. To describe if you were to push the clutch in and let off the pedal it holds the same RPM for maybe 3 seconds before starting to move lower. The only other thing is it seems as maybe a little rough at idle, not horrible but a little vibration noticed in steering wheel if you don't have your hands on it.
I have a few ideas on things to look at as not a total newbie to cars at 58 yrs old, but I know the power of a good forum and others past experiences.
The car seems to have strong acceleration and smooth transmission and clutch. She likes the car and I am just trying to be sure we have it running as good as should be expected.
Thanks in advance for your comments.
patricktxfl is offline
post #2 of 3 (permalink) Old 02-21-2019, 10:10 AM
Quoted: 364 Post(s)
As stated before in your other thread, check the motor/trans mounts. if bad they shift the geometry of the throttle cable and such. Then a good cleaning of the throttle body/butterfly and clean the Idle Air Control (IAC) valve. Also check the air intake tube from the air cleaner housing to the intake manifold for cracks, including the rubber connecting boot ends.
Good Luck!
MIA KIA 09 is offline
post #3 of 3 (permalink) Old 02-23-2019, 08:26 AM Thread Starter
Good Luck!
I looked engine mounts when purchasing and it looked like they had been replaced, but I will give it another close look.
Thanks for the list of items to check.
2012 2.4cyl rough idle...adjust idle??? jkjkjkjkjkjk 2011 - 2013 (XM) Sorento Forum 2 12-16-2018 12:39 PM
Rough Idle on 3.5 V6 kia2012sorento 2011 - 2013 (XM) Sorento Forum 4 08-17-2018 01:03 AM
97 Sportage Rough Idle Glfer65 1G (1993 - 2002) Sportage 16 06-28-2017 04:10 PM
2003 Kia Rio intermittent rough idle and off and on loss of power before shifting poi derekagraham 1G (2001-2005) Rio 10 08-19-2015 06:12 PM
Rough idle Rudgin Kia Sportage Forum 9 03-19-2007 01:48 AM
