Kia Pro Ceed - turbo - Page 2 - Kia Forum
post #11 of 198 (permalink) Old 09-06-2012, 08:40 AM
Quoted: 17 Post(s)
You are heading into a world of grief. A modified car is never as reliable as a standard one. It will cost heaps more to insure since modifiers are usually boy racers and rated accordingly. When you sell it the market is tiny and the price similar, dealers will not want it.
You admit you are strapped for cash, this is the last thing you should be doing.
Save up until you can afford the car you really want and enjoy the Ceed for what it is in the meantime.
Ceed3 is offline
post #12 of 198 (permalink) Old 09-15-2012, 07:37 PM Thread Starter
well i hope you are wrong
i know modified car isnt as reliable as a standard one but a modified car has much more to give...
insurance...well...it will go up a bit...but not much...
selling....well...i looked at some prices of Ceeds my year and in 4 years my car now worths half of what i payed...so...i dont delude myself that i am driving a honda and that my car will worth something when i am going to sell it...with turbo or without...
and i said i didnt have all the money right now and that it will take me few months...well...i managed to collect the money and i am going to tuning shop next week hopefully...
when i get a full list of what is going inside ill post it here...
jajceko is offline
post #13 of 198 (permalink) Old 09-21-2012, 06:04 AM Thread Starter
A little update. Parts have been ordered - 10 days for that and around 10 days for assembly and testing.
Some of parts are:
- Electronic PerfectPower SMT6
- Turbine Garrett T25
- Intercooler
- Gas pump Walbro 255
- Denso iridium IK 16
- BOV valve
- fifth gas injector
- bunch of pipes, hoses and other stuff
Pictures will be taken with assembly and i will post some here. Plan is to go for 0.5bar. Car also goes on LPG so i will also have to do mapping for that.
jajceko is offline
post #14 of 198 (permalink) Old 09-21-2012, 06:26 AM
dubster's Avatar
Drives: RIP :( 2010 Pro_Cee'd - Infra Red 2
Quoted: 5 Post(s)
Interested to know your dyno results before & after mate, and of course see the photo's
If in doubt, Accelerate!
dubster is offline
post #15 of 198 (permalink) Old 09-21-2012, 01:24 PM
FrEaKZoIdE's Avatar
Send a message via MSN to FrEaKZoIdE
You should take a bit compression on the engine with a higher headgasket.
FrEaKZoIdE is offline
post #16 of 198 (permalink) Old 09-22-2012, 01:49 AM Thread Starter
I have read some about lowering compression for more safety. The problem as the guys from tuning shop explained is that they couldnt find a good gasket for a permanent solution. They all need to be changed every 10-15k km. Also, i tried searching for a compression plate, but couldnt find one.
Only thing that comes to my mind is changing pistons and i dont know if i want to do that just for 0.5bar.
What do you think?
jajceko is offline
post #17 of 198 (permalink) Old 09-22-2012, 04:02 PM
Drives: 09 Pro-Ceed 1.4 ZR7
Quoted: 3 Post(s)
There are several solutions available, you can keep standard pistons and compression but just run a lower boost or if you need a lower compression you have the option of having some metal machined from either the piston crown or from the combustion chamber itself. Of course both of these options are dependant on if theres enough metal spare to remove in the first place!
Is the block cast with the crankcases or is it seperate in this engine? If you can remove the block from the cases then you have the option of fitting a spacer plate under the block to lower compression.
Are you fitting heavy duty head studs? Might be an idea on a blown motor. And then depending on the level of boost and HP/ torque increase you might need stronger rods, clutch and gearbox. And then if you really want to get serious you might want to consider a remap of the ECU or even better a fully programmable ignition.
As they say, speed costs money, how fast do you want to go? ;-)
AyJay is offline
post #18 of 198 (permalink) Old 09-22-2012, 05:18 PM Thread Starter
dont know if you read previous posts, but my plan is to go on 0.5 bar with serial setup.
i have no idea how kia ceed engine block looks . i only know that engine head is not really accessible...
clutch is also ready and will be replaced if needed (but i dont think it will be needed) and as far as electronic goes, SMT6 is going inside along with fifth injector.
the guys that are doing this made around 30 turbo conversions with the highest 2.0 hyundai coupe - 1.7bar and 400 hp
i trust them that they will do a good job
jajceko is offline
post #19 of 198 (permalink) Old 09-24-2012, 06:07 AM
Drives: Kia Ceed
Quoted: 8 Post(s)
Best of luck, you will need it. You are entering a world of grief. Have your chosen company ever done a Ceed 1.4 before or are you the guinea pig.
SWCeed is offline
post #20 of 198 (permalink) Old 09-24-2012, 06:49 AM Thread Starter
Why so negative?
No, i havent found a company that did Ceed 1.4, only found an ukraine man that did 1.6 and 2.0 and i have been talking to him for a while...
I trust this company that i choose to do a good job
jajceko is offline
Loud Turbo on the wifey's 2.0T 54lariat 2016+ Sorento 11 09-28-2017 07:11 AM
Size of alloy wheels - R16 from Ceed 2015 to Pro Ceed 2009 Montrix Kia Cee'd Forum 4 04-14-2017 01:23 PM
Kia Cee'd S turbo whistling sound christoph97 Kia Cee'd Forum 2 09-21-2015 07:26 AM
Kia Cee'd 1.6 crdi 115 WHISTLY TURBO AFTER 15000KM cypanikos Kia Cee'd Forum 38 07-21-2009 05:56 AM
Just got a Cee'd, glad there's forums like this about.... Bluetone Kia Cee'd Forum 11 04-24-2008 02:13 PM
