flip Key; how to clean mechanism? - Kia Forum
post #1 of 17 (permalink) Old 04-10-2011, 01:50 AM Thread Starter
ED209's Avatar
Drives: Kia cee'd '2' SW EcoDynamics MY11
One of my Kia keys (same as Hyundai i20 I notice) has started to stick and feel rough when opening / closing. This was on the day I helped soembody take loads of garden waste to the recycling centre, so I suspect grit / grot / dust in the mechanism to be the cause.
Has anybody managed to disassemble and reassemble one of these keys? I'm reluctant to start poking around with a screwdriver so I'd appreciate any advice on this.
Incidentally, when offered a Kia hire car last year at Munich airport (by a very apologetic Avis worker, the Kia being seen as a low budget, non-German and therefore rubbish brand) the key she was holding had suffered a failure of the spring mechanism, so I suspect it's a common problem.
ED209 is offline
post #2 of 17 (permalink) Old 04-10-2011, 02:20 AM
Drives: kia ceed SW GT line MY 2018
I usually use electrical cleaner.....just give it a quick squirt.
Failing that WD40 is as good as anything.
Chris
chris_ie is offline
post #3 of 17 (permalink) Old 04-10-2011, 02:32 AM Thread Starter
ED209's Avatar
Chris
Cheers Chris - I suspect that's all the main dealer would do, judging by my boot catch and door lock, so I might as well have a bash at that rather than take the car all the way up there. (Not that there's anything wrong with the simple, quick & easy fix!)
ED209 is offline
post #4 of 17 (permalink) Old 04-10-2011, 04:01 AM
Chris
NOJust let it dry out and flip the key a couple of times with the 'hinge' facing down.
Never use any 'oily' anti corrosion product like WD40. This will collect all the dust from your pocket in your key hinge and this will make things only worse.
Wolter
Cee'd SW 1.4 X-tra Sirius Silver
birdfeeder is offline
post #5 of 17 (permalink) Old 04-10-2011, 04:03 AM Thread Starter
ED209's Avatar
What I really want to do is open it up, clean it, and reassemble it, dry.
While I accept that WD40 might remain in the workings, attracting dust, electrical contact cleaner probably evaporates, leaving the workings clean and dry. Perhaps contact cleaner can be used to "flush out" the muck?
ED209 is offline
post #6 of 17 (permalink) Old 04-10-2011, 04:17 AM
There is really no reason to open it. I am an arborist using a flip key for 13 years now (Volkswagen and Kia). I had my keys sort of stuck many times with sand and sawdust. Just let it dry out and fiddle the mechanism. There is nothing wrong IN your key, there is just some debris in the mechanism that will fall out juggling it.
Wolter
post #7 of 17 (permalink) Old 04-10-2011, 10:19 AM
I agree with not using a WD40 type lubricant, it is parrafin based and leaves an oily residue which dust will stick to and eventually gunge up the hinge.
deeps is offline
post #8 of 17 (permalink) Old 04-10-2011, 11:42 AM
WHOA!
Hang on a minute.
I wasn't suggesting you douse the thing.
Contact cleaner is ideal but sometimes a bit of lubrication doesn't go amiss.
I've never had a problem with detritus sticking to anything lubricated with WD unless the key resides in the bottom of a handbag in which case everything gets covered in fluff including chewing gum.
Chris
chris_ie is offline
post #9 of 17 (permalink) Old 04-10-2011, 01:45 PM
WHOA!
Hang on a minute.
Chris
I wasn't suggesting you where suggesting to douse the thing.
My big red "no" was just to prevent ED209 using the WD.
I have sprayed cans full of that stuff on my Minis and Mokes electrical contacts but you just shouldn't use it on flipping keys.
Wolter
post #10 of 17 (permalink) Old 04-10-2011, 02:49 PM
Smile
Was tempted to say" what do you think it is ...RED NO DAY?"
but I won't.
or:
Yellow card for excessive use of the red no.
I'm here all week
Chris
chris_ie is offline
2012 Kia Sportage Flip Key Broken kykygruber 3G 2011 - 2016 Sportage 3 12-20-2017 08:16 PM
How can i remove and clean the Ac Evaporator ? Alex_Proceed Kia Cee'd Forum 20 06-10-2012 01:34 PM
KIA Ceed Flip Key jef22 Kia Cee'd Forum 8 06-02-2009 05:15 AM
Anyone seen a flip key? veg-o-matic Kia Carens & Rondo Forum 20 07-08-2008 08:43 AM
How can I clean my upholstery neuroticrio 2G (2006 - 2011) Rio & Rio5 4 06-08-2007 08:01 PM
