[DIY] E-brake tune - Kia Forum
 1Likes
post #1 of 34 (permalink) Old 04-05-2008, 07:26 AM Thread Starter
FrEaKZoIdE's Avatar
Send a message via MSN to FrEaKZoIdE
[DIY] E-brake tune
Sorry guys, pictures had to be taken from my cellphone, don't expect them to be very clear!
And also... there may be some English problems (the tech stuff)!
What you need:
- 12 sprocket key:
http://img301.imageshack.us/img301/3931/dsc00590vu1.jpg
- ALOT of patience (you'll see why)
1- Open the lid on the arm rest:
2- Take out the "floor" piece:
3- Find the sprocket on the end of the cable that comes from the e-brake. You'll find that there are 1 cable "coming in" that splits in to 2 (for each whell):
4- To pull so that you get less travel, you should tighten the sprocket (rotate it clockwise). If you want to loosen it, rotate it the other way. Since this is a very tight area, you can only move a few millimeters in each rotation.
WARNING:
Do not tighten it to much, you may set it to be always braking.
When if that out the "flooring" piece, you can see 2 bolts. If you loosen them you can tune the center console alignment. There are a few reports that the arm rest touches the seat when you open it. This is how you should center it.
FrEaKZoIdE is offline
post #2 of 34 (permalink) Old 04-05-2008, 07:53 AM
paulgunther's Avatar
Drives: Kia Cee'd 1.6 CRDi Optimum Plus
Gallery: 4
Wow, well done for that information, there shoudn't be anymore comments about the hand brake again :-)
paulgunther is offline
post #3 of 34 (permalink) Old 04-05-2008, 02:00 PM
HalfFull's Avatar
Drives: Cee'd 1.6 EX CRDi
Post
Thanks Freakzoide, i was going to do this DIY sooner or later, i had seen myself that cable under piece of mat so i thought i'll experiment on this in the future.It looks like prety straight forward job and ther's not much that can go wrong as long as you don't overtighten it. I'll post my results later.
HalfFull is offline
post #4 of 34 (permalink) Old 04-05-2008, 03:25 PM
Bunker's Avatar
Drives: cee'd 1.6 CRDi LS
Bloody great!
I've just been out and adjusted mine
It now locks on the 4th click. I used a one of these which make life a lot easier.
Bunker is offline
post #5 of 34 (permalink) Old 04-19-2008, 05:00 PM
HalfFull's Avatar
Thumbs up Sorted!
Sorted my one aswell, now handbrake starts working at second click and have a good hold at 4-5 clicks. Have to get used to shorter travel of lever and a bit stronger pull but in general it's much beter then it was(why they wouldn't do this at the KIA factory or why local dealers wouldn't bother?).
HalfFull is offline
post #6 of 34 (permalink) Old 01-06-2010, 07:11 AM
Drives: pro_ceed 1.6 CRDi 66kw (2008)
I did second service recently, and I asked them to tighten my handbrake. However. they didn't do it from within the cabin, they removed my rear wheels and did some adjustments there. I don't know why they prefer not to do it from within cabin.
Nikola is offline
post #7 of 34 (permalink) Old 01-06-2010, 09:15 AM
Drives: Cee'd SW LS Diesel Auto
Thks for the info FrEaKZoIdE, yr contribution makes this forum a worthwhile read. Done and dusted on mine.
Ed Jay is offline
post #8 of 34 (permalink) Old 01-06-2010, 12:36 PM
axy
axy's Avatar
I was surprised when I first realized that they have put a piece of upholstery in that box instead of a piece of plastic or something. Somebody could lose some small items stored inside, or even block a handbrake. Ceed seems well put together overall but there are a few details like this and poor quality plastics at the bottom part of the inside door panels.
* Black Kia Pro`ceed Fresh LX 1.4 16v, 109 hp, Oct/2009.
* Just about enough engine power to move it around parking lot. >:)
axy is offline
post #9 of 34 (permalink) Old 01-06-2010, 05:46 PM Thread Starter
FrEaKZoIdE's Avatar
I'd say it does it's job fine. It's thick, so I don't see the need of a plastic thing there!
That's the correct way to do it! This should be used for small adjustments.
post #10 of 34 (permalink) Old 01-07-2010, 05:15 AM
axy
axy's Avatar
Probably. But picking up that piece of fabric from the bottom of the box and removing it feels like you`ve purchased USSR car from 1956. I`ve never seen anything like that in modern cars.
axy is offline
Rear brake rotors are unique danenzmann 1G Kia Amanti & Opirus Forum 0 07-29-2018 09:01 PM
Brake Light/Electrical Issues SheDrivesAKia Kia Cerato, Shuma & Spectra Forum 3 05-28-2017 10:20 PM
Parking Brake Shoe?? burnselk Kia Carens & Rondo Forum 22 11-03-2009 04:27 PM
Brake problem nickpark83 Do it Yourself 1 08-06-2009 09:41 PM
Brake problem nickpark83 1G (1993 - 2002) Sportage 0 06-13-2009 07:57 AM
