[DIY] E-brake tune - Page 4 - Kia Forum
 1Likes
post #31 of 34 (permalink) Old 12-29-2011, 02:02 PM
Originally Posted by Jeebowhite View Post
I like the idea of the puck!
A move upmarket from a square cut from the tread of a scrap tyre.
deeps is offline
post #32 of 34 (permalink) Old 11-24-2015, 03:56 PM
Ceed 2011 SW 1.6d Handbrake slackness
I have had the huge slack on my handbrake adjusted FOC at two services. I insisted it is a mechanical fault - is there not an automatic take up to stop this happening - my brakes are not worn! Due another service soon and handbrake is again so slack that when released fully the dash brake light comes on sometimes. Design prob somewhere!
davidbvi is offline
post #33 of 34 (permalink) Old 01-18-2016, 03:38 AM
Thanks for the information.
I will try to tune it myself next weekend.
Thanks.
MifPT
MifPT is offline
post #34 of 34 (permalink) Old 11-03-2018, 10:13 AM
Drives: Kia Cee'd 1.6 CRDi 2007
Several of the posts here provide an incorrect answer to the question.
The handbrake has two adjustments:
1. Via taking up the rear brake shoe wear. As others have pointed out these are relatively easy to access BUT the shoes should not wear in normal use (since you don't apply your handbrake when moving do you?). So this is NOT the place to take up handbrake cable slack. If you adjust here you will probably remove just shoe freeplay and end up with your brakes binding.
2. Via the cable length adjuster. Cable stretch is the most common reason for a slack handbrake so this is most likely the correct place to adjust if you've not been using your handbrake when the car is moving. The cable adjuster is accessed from within the centre armrest. It is almost impossible to get a spanner on the adjuster (well done Kia) so good luck with that.
bikeman is offline
Rear brake rotors are unique danenzmann 1G Kia Amanti & Opirus Forum 0 07-29-2018 09:01 PM
Brake Light/Electrical Issues SheDrivesAKia Kia Cerato, Shuma & Spectra Forum 3 05-28-2017 10:20 PM
Parking Brake Shoe?? burnselk Kia Carens & Rondo Forum 22 11-03-2009 04:27 PM
Brake problem nickpark83 Do it Yourself 1 08-06-2009 09:41 PM
Brake problem nickpark83 1G (1993 - 2002) Sportage 0 06-13-2009 07:57 AM
