Hey everyone, just fighting the battle with the heating issue of this van. Last event, I had the shop rotor the radiator and it doesn't overheat, but it still goes three quarters the way and then cools down, but now it will not start. Anyway, just wondering if anyone knows if there is an aftermarket thermostat (cooler) for this van.
The radiator shop also stated that the design of the radiator is wrong for correct flow. The intake and exit flow of the radiator are on the same side and doesn't utilize the entire tank. If the hoses were on opposite sides of the tank the whole tank would be cooler. We put the temp gun on the radiator and it read 20 degrees different on each side of the radiator while at idle. So does anyone know if any of the radiators for different years are correctly designed and would fit the 06?
Thanks everyone
Thanks everyone
