Adjusting Parking Brake Shoes - Kia Forum
post #1 of 8 (permalink) Old 04-06-2019, 07:41 PM Thread Starter
Drives: 2015 Kia Sedona SX
Has anyone here successfully adjusted their rear parking brake shoes?
Since we bought our van, the parking brake pedal will go nearly to the floor whenever I set the parking brake. I have been wanting to adjust the parking brake, and I look at it every time I rotate the tires. The first step is to adjust the shoes in the rear brake discs using the star wheel adjuster. The problem is, I can't find that star wheel to save my life. I take the little rubber plug out of the rotor, and I shine a flashlight in there as best I can and search for the star wheel. I have looked at every "clock" position, and every angle, through the little hole, and I can't find the star wheel.
Is there some trick to locating the star wheel? According to the service manual and video's I've seen online, the star wheel should be located at about the 6 o'clock position. I just can't find it even after looking for an hour.
Has anybody else successfully adjusted these? If so, where did you find the star wheel? Or, is there some other trick?
Thanks,
GNMike is online now
post #2 of 8 (permalink) Old 05-03-2019, 09:20 AM
Drives: 2016 Sedona LX
Maybe I can remember to respond to this later but, I will try and find time myself to look for the adjuster weather permitting, as my parking brake is a little weak as well.
IMSITTINGINYOURCHAIR is offline
post #3 of 8 (permalink) Old 06-10-2019, 03:30 PM
Drives: 2017 Sedona LX+
Quoted: 19 Post(s)
According to the FSM adjuster is accessed through a hole in the rotor (different from other cars, which usually have a hold behind the hub).
http://www.kisedona.com/parking_brak...ures-1269.html
2017 Kia Sedona LX
rougeben83 is offline
post #4 of 8 (permalink) Old 06-10-2019, 04:26 PM Thread Starter
Kia Sedona: Parking Brake Assembly Repair procedures - Parking Brake System - Brake System - Kia Sedona YP Service Manual
Yes, I know this. However, you need to turn the rotor so that the access hole lines-up with the star wheel inside the hub. Where is the star wheel? 6 O'Clock position? 12 O'-Clock position? Somewhere else? I took the plug out of the access hole and looked through the hole while slowly rotating the rotor through a full 360 degrees. I can never see the star wheel through the hole.
Has anybody done this successfully? At what "clock" location is the star wheel?
Thanks,
post #5 of 8 (permalink) Old Yesterday, 10:02 AM
looks like it may be around the 6' o clock from the pictures
post #6 of 8 (permalink) Old Yesterday, 11:41 AM
Quoted: 128 Post(s)
dubber09 is offline
post #7 of 8 (permalink) Old Yesterday, 02:56 PM
just adjusted mine, they were up top, on the rt side it was more to the 1 o clock and to 11 on the left side. I have a 2015 model if this helps. you will need to shine a light to look for it in case it is not there.
post #8 of 8 (permalink) Old Today, 08:58 AM Thread Starter
Mine is also a 2015, so they should be in the same place. I thought I remember seeing something there when I was looking, but I spent more time looking around the 6 oíclock position, where they are located on other vehicles Iíve owned. Thanks, next time I rotate the tires Iíll look again.
Sent from my iPad using Tapatalk
DIY - how to remove rear rotors when they are stuck on parking brake shoes Beda 2011 - 2013 (XM) Sorento Forum 14 05-05-2019 01:47 PM
Emergency / Parking Brake - fails FWD - works REV gk-ohio 2016+ Sorento 0 03-22-2019 10:41 AM
Rear brake rotors are unique danenzmann 1G Kia Amanti & Opirus Forum 0 07-29-2018 09:01 PM
Parking Brake Shoe?? burnselk Kia Carens & Rondo Forum 22 11-03-2009 04:27 PM
Adjusting parking brake on 99 Carnival? choochoo Kia Carnival & Sedona (2002 - 2005) 1 01-26-2008 04:14 AM
