Erratic cruise control trading it in on another brand if it cannot be repaired...any - Kia Forum
 1Likes
post #1 of 14 (permalink) Old 07-04-2018, 02:05 PM Thread Starter
Drives: 2016 Kind sedona ex
I have a 2016 Sedona EX base that I bought new...since day one the cruise control is very erratic...at highway speeds the speed will vary as much as 7 mph on slightly hilly terrain, the dealer says that there is nothing they can do the correct this..this is extremely annoying and have considered trading
1sttimeKia! is offline
post #2 of 14 (permalink) Old 07-05-2018, 07:41 AM
Drives: 2017 Sedona LX+
Quoted: 19 Post(s)
At what speeds is this happening? Try turning off the "ECO" mode, it may help the transmission kickdown sooner when the cruise control senses the speed drop/easier modulation from the throttle mapping.
2017 Kia Sedona LX
rougeben83 is offline
post #3 of 14 (permalink) Old 07-07-2018, 04:27 PM Thread Starter
I notice it at speeds above 30 mph on slight inclines...gets worse at higher speeds but oddly enough it does better on steeper inclines as it is quicker to downshift and I never use eco mode
post #4 of 14 (permalink) Old 07-08-2018, 07:52 PM
Drives: '14 Cadenza SX-L '16 Sedona SX
Quoted: 31 Post(s)
Not sure if mine has a unique quirk or if it might apply here, but I noticed that if I just leave it in the drive mode it was in when I shut it off, the performance and mpg seem a little weak (mpg is definitely 1-2mpg less). If I cycle through the 3 modes: Eco, Comfort, Normal, back to where it was, then it seems to pep up a bit and mpg rises again. It's a nuisance, but it does seem to make a difference.
Kia-Driver is offline
post #5 of 14 (permalink) Old 07-13-2018, 03:14 PM
Quoted: 19 Post(s)
From the Owner's manual:
The cruise control system allows you to program the vehicle to maintain a constant speed without depressing the accelerator pedal.
This system is designed to function above approximately 40 km/h (25 mph).
If the cruise control is left on, (CRUISE indicator light in the instrument cluster illuminated) the cruise control can be switched on accidentally. Keep the cruise control system off (CRUISE indicator light OFF) when the cruise control is not in use, to avoid inadvertently setting a speed.
Use the cruise control system only when traveling on open highways in good weather.
Do not use the cruise control when driving in heavy or varying traffic, or on slippery (rainy, icy or snow-covered) or winding roads or over 6% up-hill or down-hill roads.
✽ NOTICE
During normal cruise control operation, when the SET switch is activated or reactivated after applying the brakes, the cruise control will energize after approximately 3 seconds. This delay is normal.
To activate cruise control, depress the brake pedal at least once after turning the ignition switch to the ON position or starting the engine. This is to check if the brake switch which is important part to cancel cruise control is in normal condition.
WARNING - Misuse of Cruise Control
Do not use cruise control if the traffic situation does not allow you to drive safely at a constant speed and with sufficient distance to the vehicle in front.
So, 30mph may be right at the lower limit of reliably using the cruise control, and don't use it when there's any sort of change in elevation/turns. Basically just straight highway cruising...
2017 Kia Sedona LX
post #6 of 14 (permalink) Old 07-27-2018, 10:39 AM
Drives: 16 Sedona SXL
Quoted: 16 Post(s)
I think it is just overall a so-so engineering part of the car. I set it once at 5 over the speed limit, came down a hill where a cop was waiting, and by the time I'm down the crest I was a little over 10 over the limit and actually got pulled over! Thankfully I just got a warning.
Driving the same piece of road in my wife's X3 with cruise on, the speed differential on a hill never went beyond 2-3 mph. The BMW seems to be actively managing the speed at all times keeping it pretty stable. On a down hill, the Sedona essentially almost coasts at first, then will give an abrupt downshift once you're like 5 mph over to try to slow the van down. Not sure how the BMW system works, but it manages to keep the speed much more stable without even downshifting. Maybe it is making a lot more throttle adjustments and even using the brakes a little bit on a downhill stretch.
rtb001 is offline
post #7 of 14 (permalink) Old 07-27-2018, 03:44 PM
Quoted: 19 Post(s)
Agreed, I think the cruise on these vans are basic at best. Both of my Subaru's have a little more "active" control of cruise control, albeit both are manual transmission. Some systems rely more heavily on engine braking depending on how the cruise control system maintain's throttle position (older systems use vacuum operated, nowadays with most cars being throttle-by-wire, this is less common), and the various sensors the system uses to detect speed and obstacles - more the latter if you have one of the auto-braking/collision warning systems in your car.
2017 Kia Sedona LX
post #8 of 14 (permalink) Old 04-19-2019, 10:32 PM Thread Starter
Well my “cruise control” problem went awayI traded it in the end of February for a new left over 2018 SLX which has “adaptive cruise control”.... much better system than my 16’ had.
I don’t know if all 16’ EX’s were like mine or not but I’m much more satisfied with my new cruise control. Now if I can solve a problem with the “blind spot detection” in my new SXL I’ll be a real happy man.
post #9 of 14 (permalink) Old 04-22-2019, 08:07 AM
Drives: Sedona 2016
What issue is that?
Stevemd is offline
post #10 of 14 (permalink) Old 04-23-2019, 05:47 AM
Drives: 2015 Kia Sedona SX Limited with Tech Package and Pursuit Remote Start New Beige/Beechwood Pearl
Quoted: 13 Post(s)
Adaptive Cruise control was one of the main reasons I went with Sedona in 2015 and it has worked great since I've owned the van. The only downside is when I drive our other car and use the cruise control I have to remember that it's not adaptive :}
Just Looking is offline
2016 Kia Optima Smart Cruise Control Warning preilly 4G (2011+) Optima 5 11-21-2016 08:05 PM
2016 Kia Optima SXL adaptive cruise control preilly 4G (2011+) Optima 2 10-24-2016 05:07 PM
Cruise Control prevents acceleration ysorento 2014 - 2015 Sorento Forum 1 08-12-2015 07:47 PM
03 Kia Rio cruise control yellow tibby 1G (2001-2005) Rio 2 01-04-2009 10:11 AM
sorento cruise control fault langfordj1 2003-2010 Sorento Forum 1 10-22-2007 02:33 PM
