Convert positioning lights to DRL - Page 3 - Kia Forum
 6Likes
post #21 of 26 (permalink) Old 03-13-2019, 11:21 AM
Drives: 2018 Sedona SXL
Did you have to run the wire to the engine bay or did you locate the wire under the dash? If the bay, where did you penetrate that? If under, about where?
mykeytea is offline
post #22 of 26 (permalink) Old 03-13-2019, 04:47 PM Thread Starter
mletchworth's Avatar
Drives: 2016 Sedona SX
Quoted: 17 Post(s)
I didn't do anything inside the cabin or under the dash. The fuse I tapped is in the engine bay fuse box.
new minivan dad born August 2016
mletchworth is offline
post #23 of 26 (permalink) Old 03-15-2019, 08:48 AM
Well duh to myself. Thanks for that info.
mykeytea is offline
post #24 of 26 (permalink) Old 03-15-2019, 10:49 AM Thread Starter
Quoted: 17 Post(s)
You're welcome. I guess you could add a switch inside the van, but I don't need a switch.
post #25 of 26 (permalink) Old 07-09-2019, 11:56 PM
Drives: 2015 Kia Sedona SX-L
So basically you:
1. Cut the green wire on the drivers side
2. Cut the yellow wire on the passengers side
3. Tap into the green and yellow wires and run those to the Add A Circuit
Am I correct? Also, what fuse can I tap into since I have an SX-L with radar cruise control.
TIA
raven69david is offline
post #26 of 26 (permalink) Old 07-10-2019, 10:17 AM Thread Starter
Quoted: 17 Post(s)
Originally Posted by raven69david View Post
So basically you:
TIA
Yep, it's as easy as that. You could tap the same fuse if you want. These little LEDs aren't using too much load. The add-a-circuit should handle it just fine.
DIY - Positioning Lights as DRLs josuet 2016+ Sorento 81 02-04-2019 10:28 PM
Positioning lights "burnt out" 76camaro 2014 - 2015 Sorento Forum 17 12-03-2016 04:12 PM
Brightness of Positioning lights / Loudness of safety systems shabx 2016+ Sorento 2 10-09-2016 12:11 PM
2001 Spectra Interior/Tail lights turn on/off when they like. Linake Shuma & Spectra (1997-2003) 2 12-31-2011 05:25 PM
Problem with Daytime Running Lights - Canadian Sorento Jason_S 2003-2010 Sorento Forum 5 07-20-2008 07:13 PM
