Light bulbs for 06 Sedona - Kia Forum
post #1 of 3 (permalink) Old 11-26-2008, 06:34 PM Thread Starter
Repsolal's Avatar
Drives: 06 RED Sedona EX power
2006 Kia Sedona Car Light Bulb Size Diagram
Low Beam Headlight Bulb Size: H7
High Beam Headlamp Light Bulb Size: H1-55W
Parking Light Bulb Size: 168 or 2357A
Front Turn Signal Light Bulb Size: 2357A
Rear Turn Signal Light Bulb Size: 1156A
Tail Light Bulb Size: 2357
Stop Light Bulb Size: 2357
High Mount Stop Light Bulb Size: 921
License Plate Light Bulb Size: 168
Back Up Light Bulb Size: 1156
Front Sidemarker Light Bulb Size: 168
Dome Light Bulb Size: DE3175
Step/Courtesy Light Bulb Size: 168 or 6418
Repsolal is offline
post #2 of 3 (permalink) Old 12-15-2008, 06:33 PM Thread Starter
Repsolal's Avatar
Anyone change a front left side turn signal bulb ??
What the heck do i need to remove to gain access to change the bulb ??
without dropping the motor
Repsolal is offline
post #3 of 3 (permalink) Old 12-17-2008, 10:44 AM
Drives: 2006 Sedona, 2001 Taurus
I have changed the passenger side headlight on mine and I think all the lights are in the same housing. You have to remove the 16 or 18 phillips head screws from the engine shroud. Take the shroud off. Then there are two 8 or 10 mm bolts holding the light cluster on the car. Remove the two bolts and the whole light cluster lifts out of the engine compartment. Unplug the power cable, take the plastic cap off the back of the socket and replace the bulb.
Took me about 20 minutes, easier than it looks.
Careful though, I cut the hell out of the back of my hand on a sharp piece of metal when I reached in and lifted the light cluster out.
talleyrand is offline
KIA Fog Light LED Bulbs! Plug & Play Install! Upgrade your lights! Diode Dynamics Diode Dynamics 39 06-21-2018 05:28 PM
2017 Sedona ex brake light housing removal. ptguy0618 Kia Carnival & Sedona 2015+ 1 09-28-2017 11:00 AM
Need help with Tail light problem 2008 Sedona Radman171 Kia Carnival & Sedona 2006+ 2 06-19-2017 07:58 AM
2006 Sedona 3rd brake light removal thehothit Kia Carnival & Sedona 2006+ 1 11-20-2007 06:17 AM
Sedona Gear Indicator bulbs abamains Kia Carnival & Sedona Forum 1 04-03-2007 02:18 PM
