Drivers side water leakage '08 Sedona - Kia Forum
post #1 of 6 (permalink) Old 05-22-2019, 08:28 AM Thread Starter
Drives: 2008 Sedona, base model.
Quoted: 10 Post(s)
Recently we noticed water dripping onto the floor (and drivers feet) from under the dash. I'd not noticed it before but from the condition of the carpet this has probably been going on for a long time. I am sure it's not an evaporator drain problem as A/C has not been in use.
Have others had this problem? Any guidance?
Thanks.
amuller is offline
post #2 of 6 (permalink) Old 05-22-2019, 02:02 PM
Drives: 2009 Kia Sedona LX
Quoted: 8 Post(s)
Heater core.
rrrchavez is offline
post #3 of 6 (permalink) Old 05-22-2019, 02:11 PM
Quoted: 8 Post(s)
I have an 09 Sedona and the heater core is located behind the instrument panel, towards the driver side. See the attached picture.
Check the hoses and the heater core for a leak. This is almost certainly the source of your problem. And unfortunately it's not going to be a cheap fix unless you have a buddy that works on cars. The parts are cheap, it's the labor that jacks up the repair cost because of how much time it will take to take everything a part then put it back together.
File Type: jpg Screenshot_2019-05-22-12-05-13-1_1558552295232.jpg (22.7 KB, 18 views)
post #4 of 6 (permalink) Old 05-30-2019, 07:39 AM Thread Starter
Quoted: 10 Post(s)
Thanks for the responses but I do not think it is a coolant leak for several reasons:
We know the smell of hot antifreeze and that's not present;
There is no coolant level drop;
We only get the wetness during or after a rainstorm.
So, we think it has to be a leak from the HVAC plenum, or a clogged drain, or....
amuller is offline
post #5 of 6 (permalink) Old 06-12-2019, 07:14 AM
Drives: 2007 Kia Sedona EX
same problem I had when my 07 was new. The drain hose for the sun roof is pinched. open sun roof and you can see the hose that drains water from the sun roof channel. It takes excess water and goes down the windshield frame and discharges on the ground. Replace it. good luck!
geoga is offline
post #6 of 6 (permalink) Old 06-12-2019, 07:19 AM Thread Starter
Quoted: 10 Post(s)
This one doesn't have a sunroof. But I am thinking there is some sort of air intake plenum with a drain that could be pinched or clogged?
am
amuller is offline
Drivers side camera failure on SX+ Nick Van Vlymen 2016+ Sorento 1 04-05-2018 11:11 AM
2016 Sorento EX No Hot air on Driver's side Drambuie 2016+ Sorento 12 02-10-2017 04:53 PM
Drivers side water leak Cheekie B 2011 - 2013 (XM) Sorento Forum 1 12-07-2016 02:28 PM
Problems with driver's side door lock. Jimbo24 Kia Carnival & Sedona Forum 3 10-23-2006 06:45 PM
