07 Sedona P0016 - Page 3 - Kia Forum
post #21 of 38 (permalink) Old 03-10-2018, 03:46 PM Thread Starter
Drives: 2007 Kia Sedona EX
Quoted: 4 Post(s)
Question need help
so the intake is out of the way and I cant get the front cvvt solenoid out. any tricks to taking it out? I changed rear plugs and found the driverside most plug was not tight, and the coil pack bolt was also loose. also I did verify that the front screen is intact,
jlam6765 is offline
post #22 of 38 (permalink) Old 03-10-2018, 04:28 PM
Quoted: 262 Post(s)
Probably suction doesn't want to give up it's hold. Did you try tapping on it a bit with a small hammer?
kiaguy002 is offline
post #23 of 38 (permalink) Old 03-10-2018, 05:43 PM Thread Starter
Quoted: 4 Post(s)
it hits the lower half of the intake. so close but it wont clear. I just put it all back together and it started hard and gave a crankshaft position sensor code p305 I think.
jlam6765 is offline
post #24 of 38 (permalink) Old 03-10-2018, 06:30 PM
Drives: 06 Grande Carnival
Quoted: 17 Post(s)
My OCV was difficuilt to extract, there is an 'o' ring on the body, which I assume adheres to the bore that it is in. I persisted with twisting and pulling and it eventualy came loose.
P305 is missfire cyl 5.
bopbo is online now
post #25 of 38 (permalink) Old 03-10-2018, 08:17 PM Thread Starter
Quoted: 4 Post(s)
I got 90% out then it hits the intake. even if I did get it out not sure how I would get the new one in.
jlam6765 is offline
post #26 of 38 (permalink) Old 03-10-2018, 09:14 PM
Quoted: 262 Post(s)
Originally Posted by jlam6765 View Post
... I changed rear plugs and found the driverside most plug was not tight, and the coil pack bolt was also loose. ....
Given the P0305, you might want to take a look at that one again. One good simple test is to swap the coil pack and see if the cylinder misfire follows that coil.
post #27 of 38 (permalink) Old 03-11-2018, 08:54 AM Thread Starter
Quoted: 4 Post(s)
Going to go drive it this morning. I will update when I have results. As far as the front cvvt it hits the lower part of the intake ( the valley) and will not come out. I get it 90% out (I can see the screen part) but that's it.
jlam6765 is offline
post #28 of 38 (permalink) Old 03-11-2018, 09:17 AM
Quoted: 262 Post(s)
... As far as the front cvvt it hits the lower part of the intake ( the valley) and will not come out. I get it 90% out (I can see the screen part) but that's it.
Sorry, but I'm not familiar with your V6 engine, and don't have a service manual for it either. Perhaps someone who knows that engine can chime in and explain how to get that OCV out. But if the screen is intact, then it should hopefully be ok to leave it in.
post #29 of 38 (permalink) Old 03-11-2018, 09:26 AM Thread Starter
Quoted: 4 Post(s)
that's what I went with. Not sure why I got the Crankshaft code at start up. Going to road test it now. Be back soon. So it started with no code. I drove it about ten miles. Got it fully warmed up to temperature. Shut it off and restarted. P0355 code popped. then misfire codes. reset the codes and shut it off and restarted it. Drove back home with no issues....
jlam6765 is offline
post #30 of 38 (permalink) Old 03-11-2018, 11:08 AM
Quoted: 262 Post(s)
That code makes it now seem even more likely that the problem is a bad coil. After checking the coil connector and nearby wiring, swap the #5 coil with another to see if the code changes to another cylinder.
Traded the Sedona on a Chrysler Pacifica Limited today SWSedonaSX-L Kia Carnival & Sedona 2015+ 6 11-16-2017 02:38 PM
Test drove a new 2018 Honda Odyssey today! Thoughts vs Sedona and Pacifica SWSedonaSX-L Kia Carnival & Sedona 2015+ 20 09-06-2017 09:36 AM
P0016 Error on 2007 Sedona Phanom Kia Carnival & Sedona 2006+ 3 06-01-2017 09:32 AM
My 3,000 mile Sedona report mitchedo Kia Carnival & Sedona 2015+ 1 10-28-2015 01:00 PM
