Sedona 2003 ABS Warning Relay ??? - Kia Forum
post #1 of 3 (permalink) Old 06-02-2019, 06:42 PM Thread Starter
Drives: Kia Sedona 2003
Quoted: 3 Post(s)
Hello,
"Kia 95610-FD400 Polyester" appears to be a “warning module” as part of the ABS system attached to the wheel well under the brake booster.
It has 5 wires: Y/R, Y, R, B, P (looks pink). I have found 7 different names for it on internet. No descriptions as to function or schematic.
Can anyone please explain wiring and what goes on there?
Thanks for your time.
Mike.
K03S is offline
post #2 of 3 (permalink) Old 06-06-2019, 10:12 PM
Drives: 06 Grande Carnival
Quoted: 17 Post(s)
It connects the ABS module to the instrument cluster and the ignition switch, it lights the ABS lights and the brake warning light if there is a fault. which eplains the warning relay desription. I got the info from 'autozone' wiring scematics.
Brian
bopbo is offline
post #3 of 3 (permalink) Old Today, 02:40 PM
Drives: 2005 Sedona EX 117,000 Miles
Brian
Yes this is right on the money!
I had an intermittent abs light, would come on and only last a few minutes or so then go out.
A code was never stored when I went to read it with scan tool.
And light finally came on and stayed on. Scanned it and could not communicate with abs computer. Diagnosed it down to bad abs pump unit.
Replaced with known good pump.
Light remained on and scanner still could not communicate with unit.
Never did figure it out and just run it old school without abs.
The only time the light does go out is if I remove the relay. If it is plugged in the ABS light is on.
Hope that helps!
Sent from my VS988 using Tapatalk
thorze is online now
