GDI carbon buildup/ CRC intake valve cleaner - Kia Forum
post #1 of 5 (permalink) Old 09-06-2018, 08:14 PM Thread Starter
Drives: 2019 Kia Sorento Ex
Quoted: 86 Post(s)
I'm aware of and understand the carbon buildup on the rear of the intake valves on GDI engines. Being conscious of this, I've been looking into the issue and read about the CRC Intake Valve and Turbo Cleaner that can be used to remove carbon I wonder if it really works and could be used as a preventative measure to prevent the carbon buildup issue. I'm wondering if anyone has any personal information on this product. Does it really work, is there any negative effects that it can cause, is it just a over-hyped scam? If anyone has additional information on this, please enlighten me. I'd be using it more as a preventative measure at this point on my 2019 3.3l v6 Sorento.
PureBlue0229 is offline
post #2 of 5 (permalink) Old 09-09-2018, 01:24 PM
Drives: 2017 Kia Sorento LX V6 AWD
Quoted: 18 Post(s)
Good question! I’m a bit “scared” to use it on my ‘17 Sorento V6 with 16k miles.
I’ve cleaned the throttle body... which was simple enough... but dumping a full can of intake cleaner on top of those valves I’m not so sure of. I’ve heard everything from it being “snake oil”... to folks who use it yearly with 250k+ on their engines that swear by it.
Apparently the older “Lambda” and “Theta” engines have a way to spray gas on top of the valves... but our newer 3.3L V6’s I have no idea.
If anyone knows specifically about the 3.3L V6... we would like to hear from ya!
I’m the type that likes to leave an engine alone as long as it’s under comprehensive warranty... so I’m not doing a thing until I get a good idea what’s going on.
Joplin-Kia is offline
post #3 of 5 (permalink) Old 09-09-2018, 07:09 PM
DavesSpectra's Avatar
Quoted: 444 Post(s)
To both of you....
You need to research "oil catch cans"...
The carbon build up comes from reusing crankcase air by rerouting it to the throttle body... This "air" contains oil from blow by that would in older engines be washed off the valves with the gas injected into the intake manifold... Because the newer engines now inject gas directly into the cylinders (bypassing the intake valves) the oil never gets washed off and ends up cooking on the valves and coating the inside of the intake manifold...
I just purchased a salvage 2014 Optima GDI with 56k miles on it... It had the plastic intake manifold there was oil covering the insides and the intake valves were just forming carbon buildup...
A oil catchcan re-routes the PCV air through it and the baffles and filter material catch the oil (and other deposits) and still allows the air to be recirculated through the engine... You can then drain the can of the oil...
watch this...
DavesSpectra is offline
post #4 of 5 (permalink) Old 09-11-2018, 10:16 AM
Drives: 2018 Sorento LX V6 AWD Conv. Pkg. Tech Pkg.
Quoted: 69 Post(s)
Do the newer Sorento's have the extra injectors that wash over the valves?
JohnH123 is offline
post #5 of 5 (permalink) Old 09-11-2018, 10:19 AM
steve807's Avatar
Drives: 2019 Sorento SX L (FWD)
Quoted: 34 Post(s)
No, no extra injectors. That would drive the cost and complexity way up.
Never happen.
steve807 is offline
  Kia Forum > General > General KIA Non-Model Specific Discussion
Intake valve cleaner Coolwhip 2016+ Sorento 43 11-08-2018 12:24 PM
intake valve cleaner Ali Alzayadi 4G 2016-2018+ Sportage 2 06-12-2018 02:52 PM
GDI / Intake valve cleaning/ Top Tier Gas 2014 Sorento LX 2014 - 2015 Sorento Forum 10 04-09-2018 09:16 PM
Using CRC Intake Valve Cleaner On 3.3 Engine Lanyard 2014 - 2015 Sorento Forum 1 08-19-2016 04:24 PM
CRC Intake valve cleaner ap0c552 3G (2012 - 2017) Rio 14 07-21-2015 03:33 PM
