OBDii Diagnostics with SCANNER - Kia Forum
 4Likes
post #1 of 25 (permalink) Old 08-10-2011, 05:00 PM Thread Starter
aquanaut20's Avatar
Quoted: 251 Post(s)
The screen shots are the basic required information of an OBDII compliant vehicle.
The screens will be noted left to right from top to bottom.
the screen with the Six dials contain;
Throttle .. Vacuum
Tachometer .. Speedo
Intake Air Temp .. Coolant Temp
The second screen contains the
air (MAF)......fuel (adjusted for 14/1 ratio, LTFT)
O2 voltage
The first dials of value are the IAT and the Coolant, they must be equal (ambient) when the engine is cold..
Second value (TPS), engine off, key on, throttle depressed slowly must register on gauge with a gradual sweep with no jitter/jumps.
On cold start the ECU checks the coolant temp and if <180* will initiate rich injection and open ISC (idle control), colder the value the richer the injection(longer pulse).
As the coolant temp increases the ECU commands the ISC and Injection pulse to reduce fuel/air, lowering RPM to +/-800.
On reaching coolant temp >170* the ECU obtains CL (closed loop) and allows the O2 S1 to control the data based on the amount of unburnt oxygen in the exhaust prior to CAT.
In order to achieve the stoic 14.1/1 AFR ratio, the ECU considers the coolant temp + MAF + O2 + TPS.
The second screenshot displays the MAF value. Once running the ECU adjusts the fuel (STFT) based on the collected data, the STFT fluctuates to quickly to be useful at this point so the LTFT is required The closer to 0.0 the better, +/-10 requires attention, and above serious investigation. The system will trigger a CEL somewhere close to 15% and above..
It is important to recognize the O2 values must switch rapidly and even top to bottom. If the readings are consistently High(rich mixture) or Low(O2 sensor is biased or sees an O2 leak) and if slow has become lazy..
It is important to know that the system cannot have any illegal air leaks, either post MAF>prior combustion chamber, or post combustion chamber>pre CAT. Hence the requirement for the Vacuum gauge. The S2 has no bearing on the fuel air ratio and the sensor only monitors the values exiting the CAT
Remember switching/replacing parts and guessing just wastes time and $$$.....
The trick is to get the engine working correctly.
Hope this has given you a start......Philip
ID:	9150   Click image for larger version
Sloppy likes this.
aquanaut20 is offline
post #2 of 25 (permalink) Old 08-10-2011, 06:21 PM Thread Starter
aquanaut20's Avatar
Quoted: 251 Post(s)
Code reader vs Scanner
1st frame is part of my electronics cabinet
2nd frame, good old OBDI code reader <1996.
3rd frame, USB OBDII Scanner with laptop OBDII/CAN
4th frame, Combo OBD 1&2 code reader OBDII/CAN
5th frame, MS509 OBDII Scanner with live data and graphing capabilities..OBDII/EOBD/CAN
Name:	OBD Toolbox.jpg
ID:	9152   Click image for larger version
ID:	9153   Click image for larger version
Name:	OBD BT comp.jpg
ID:	9155   Click image for larger version
ID:	9156   Click image for larger version
Name:	OBDII scanner 509.jpg
post #3 of 25 (permalink) Old 08-11-2011, 11:42 AM
Premium Member
1fastkia's Avatar
Quoted: 17 Post(s)
1987 Mazda RX-7 GLX
The Old
1fastkia is offline
post #4 of 25 (permalink) Old 08-11-2011, 11:57 AM
Quoted: 704 Post(s)
I have the older version of this one with the ElmScan5 interface module (old serial port) - I don't use it in my line of work, only hobbyist use.
My interface is much the same as this one, which is only $29 with software - http://scantool-net-llc.amazonwebsto...source=froogle
DarrenPEI likes this.
ron1004 is offline
post #5 of 25 (permalink) Old 08-11-2011, 12:07 PM Thread Starter
aquanaut20's Avatar
Quoted: 251 Post(s)
I have several with RS232, that I used with an old XT, a Palm M105 and a Palm IIIX.
Much more cumbersome to setup and use...
My present toy is a BT dongle permanently installed in my daily driver and Torque on my Android smartphone... Immediate references, no setup, just tap the screen once.... Just love it...
Still go back to my Harrison/Palmer RS232 (once in a while), as I have extended OBDII and mode 6 capabilities..... Philip
Name:	OBDII old Harison.jpg
ID:	9163   Click image for larger version
Name:	OBDII Palmx2.jpg
post #6 of 25 (permalink) Old 11-11-2011, 03:27 PM
Quoted: 704 Post(s)
Can this one display the ISC/IAC valve duty cycle?
Autel
http://www.tmart.com/Autel-MaxiScan-...ta_p88572.html
ron1004 is offline
post #7 of 25 (permalink) Old 03-17-2015, 02:42 PM
DarrenPEI's Avatar
Drives: 2008 Kia Rio5. 2008 Honda CBR125R
Quoted: 9 Post(s)
Post Code reader purchase
Hi all, I am considering buying a trouble code reader. I am looking for any advice or recommendations on this purchase. Are these code readers universal ie will it work on any brand of car? Also , what kind of price range do they sell for? Are there any brands of code reader that I should look for , or are they all fairly good?
I enjoy doing small repair/maintenance work on my car. Is this a good purchase?
Thanks,
Darren.
DarrenPEI is offline
post #8 of 25 (permalink) Old 03-17-2015, 02:47 PM
Quoted: 704 Post(s)
Thanks,
Darren.
You're better off buying a full scanner, not just a code reader.
Do a search here and on Google and you'll find Bluetooth ones for around $10 with free software.
https://www.kia-forums.com/1g-1994-20...scanner-2.html
ron1004 is offline
post #9 of 25 (permalink) Old 03-17-2015, 03:44 PM
DarrenPEI's Avatar
Quoted: 9 Post(s)
Thumbs up Scanne
Thanks Ron. Much appreciated.
post #10 of 25 (permalink) Old 03-23-2015, 05:47 PM
DarrenPEI's Avatar
Quoted: 9 Post(s)
Obd2
Wow , saved a lot of money ( and grief )via this forum. I went to Canadian Tire today ( a large Canadian auto parts franchise ) looking for an OBD2 diagnostic scanner. They had two models , and the cheapest was 130$ CDN. The links provided here show me where to order the Maxiscan MS509 for a lot less. Thanks for the help.
Darren.
OBDII scanner - UltraGauge MX tedburger 3G 2011 - 2016 Sportage 4 03-28-2016 01:55 PM
Lowest $$ for OBDII WiFi or BT aquanaut20 1G (1993 - 2002) Sportage 44 01-05-2016 08:41 AM
OBD scanner zlotvor 2G (2006 - 2011) Rio & Rio5 10 01-22-2010 05:58 AM
OBDII Question ajuk 2G (2006 - 2011) Rio & Rio5 0 04-02-2008 04:59 PM
99 Sportage without OBDII ??? bedemgrad 1G (1993 - 2002) Sportage 1 11-22-2007 07:43 PM
