Checking an alternator with a multimeter. - Kia Forum
 1Likes
  • 1 Post By kiaDIYguy
post #1 of 3 (permalink) Old 03-11-2010, 03:51 PM Thread Starter
Memorial Super Moderator
pulsar86's Avatar
Quoted: 3 Post(s)
Checking an alternator. Start with a fully charged battery.
1. Switch on all lights for 5 minutes to reduce the charge in the battery and apply a load to the circuit.
2. Start the engine and bring revs to around 2500. An amp reading across the battery terminals should be around 75% of the alternators rated output.
3. Switch off all lights and run the engine at 1500-2000 revs until the indicated charge is below 10 amps. A volt reading should now be between 14 and 15 volts.
If the voltage reading is above 15 or below 14 the alternators voltage regulator is faulty.
pulsar86 is offline
post #2 of 3 (permalink) Old 12-29-2014, 04:02 PM
where the dlc located on the 1999 kia pride
sammy1 is offline
post #3 of 3 (permalink) Old 01-10-2015, 01:22 AM
Warning: Do not connect the ammeter across the battery terminals!! That is a dead short and can cause your battery to explode! The correct connection of an ammeter is in series with the circuit under test. In this case, it should be between the battery + terminal and the large wire that comes out of the alternator. The ammeter should be able to handle 75 or more amperes.
The correct connection of the voltmeter should be across the battery terminals.
SedonaXL8 likes this.
kiaDIYguy is offline
Digital Multimeter for $9 at Amazon ron1004 Do it Yourself 2 05-28-2019 05:41 PM
Checking in CADBERT New Member Area/Introduction 2 08-06-2018 04:12 AM
Checking Fluid on Rio Auto Transmission RioJohn 3G (2012 - 2017) Rio 0 11-14-2017 06:13 PM
checking transmission level 4thand26 Kia Carnival & Sedona (2002 - 2005) 3 12-04-2015 02:54 PM
adjustment afr with digital multimeter benvin Do it Yourself 2 07-19-2009 10:30 AM
