DIY oil change void warrenty? - Kia Forum
 5Likes
post #1 of 15 (permalink) Old 10-18-2013, 04:26 PM Thread Starter
Drives: 1983 subaru brat and about 4 other subarus
Hello,We just got a 2013 Kia Soul Base.It has 2600 miles on it and I'm worried sick that puttin that many miles on the first change is not good for the new ride...I called the dealer and they want $30 bucks for an oil change and should treat it like any other oil change.. i like to change my own oil and will probley change it at 5,000 instaed of 7,500 as the dealer says. So can I do it myself or will that void the warrenty? We really like our new Soul.Thanks,Toddnick
toddnick is offline
post #2 of 15 (permalink) Old 10-18-2013, 06:33 PM
KIAZILLA's Avatar
Quoted: 6 Post(s)
Document and keep receipts for the oil and filters and you will be good. I would recommend using KIA factory filters to avoid any warranty issues should the arise. You can buy KIA filters off Ebay really cheap too. You have to buy five or six at a time, but you end up paying around three to four dollars a filter this way. I have done this since my car was new.
Pretender likes this.
KIAZILLA is offline
post #3 of 15 (permalink) Old 10-19-2013, 02:11 AM Thread Starter
thank you
Thanks...I was planing on using there filters.The guy at the Kia shop told me the Kia oil filters hold pressure so after the car is turned off its still "Pressureized" as far as having oil pressure when you first start up..Oh these Guys...so smart !! So just to be sure ,where were you told about it being ok about changin your own oil?.Just in case I want to have more to say than"Oh this guy on the Kia Forum told me" haha But seriously Is it stated somewhere? Thanks Toddnick
toddnick is offline
post #4 of 15 (permalink) Old 10-19-2013, 03:54 PM
KIAZILLA's Avatar
Quoted: 6 Post(s)
I don't know that it is stated anywhere, but common sense tells me that as long as the oil is changed at regular intervals, using the proper oil, and using KIA filters, then there could not be any warranty issues. I suppose if you did something dumb like, forget to tighten the filter or cross thread the drain plug, then it would be a different story. If I remember correctly, when I bought mine, I did ask the service manager about changing oil and he said no problem but did recommend using factory filters.
KIAZILLA is offline
post #5 of 15 (permalink) Old 10-20-2013, 12:50 PM Thread Starter
I was told the same thing about using there filters..But when I asked about changing my own oil they said that Kia is "Kind of wierd" about that.... So is it BS or ok to change my own oil. I too would think that it would be "Common sence" but in this day and age common sence is out the window......don't you think...Thanks,toddnick
toddnick is offline
post #6 of 15 (permalink) Old 10-20-2013, 01:39 PM
Muttdawg's Avatar
Drives: 2013 Rio 5 EX, 1967 Chevy C10
Quoted: 29 Post(s)
As long as you follow the advice given to you above, you'll be fine. They can't force you to use their service department for oil changes, repairs, etc. As long as you keep receipts, follow the directions on kiatechinfo.com and all, you'll be fine. How do I know this??? I've been in the autoparts business for 18 years now. I also am friends with several mechanics that work for either themselves or independent shops. If we were forced to have our vehicle serviced at the dealer, neither I nor any of my mechanic friends would have jobs.
As a side note, I am trying to get back to the filter rep about Kia and using only Kia filters. I have always used Wix and since what we sell are rebranded Wix filters, I am curious as to why they would not be good enough to use on my Rio.
Muttdawg is offline
post #7 of 15 (permalink) Old 10-20-2013, 06:17 PM Thread Starter
oil thoughts
Hey Mutt,well I'm feeling better all the time about doing my own maintence.Thanks for the advice...I was told the kia oil filters will hold pressure so when you fire up your car it already has oil pressure... is that right? If so Thats a good plan....The more I look into my Kia Soul the more I like it.I did notice that on the last 2" on my dipstick is "textured" for lack of a better word. Its ruff and it seems you can read your oil level better.Now did they do that for that reason OR is that from something in the oil...?I remember when I added some Prolong to my Subaru Brat it changed the color of the dipstick... So thanks again for any thoughts...Toddnick.
toddnick is offline
post #8 of 15 (permalink) Old 10-20-2013, 06:59 PM
Muttdawg's Avatar
Quoted: 29 Post(s)
Here's an exploded view of an oil filter:
What they are most likely referring to is the anti-drainback valve. This keeps oil in your engine instead of draining back into the filter and keeps you from having a dry start.
I'm pretty sure the section on the dipstick is that way for the reason you said, to be able to read your oil level better. My Rio's dipstick is a different shade of gray on the end where the oil level is measured.
Muttdawg is offline
post #9 of 15 (permalink) Old 10-21-2013, 01:12 AM Thread Starter
You know when I saw that on the end of the dipstick i thought these guys really are going out of there way just so you can read your oil level better.If you feel it its ruff. the more I learn about this little base Soul the more impressed I am.I just turned 60 last summer and just in my lifetime I have seen some serious auotmobile advancements. Flat head 6's with felt oil seals and grease zerts on EVERYTHING...even on the clutch linkage... Does the Soul even have any zerts? I know that modern ball joints can last 200,000 miles(well on subarus anyway) so would a zert give you another 200,000 haha Anyway great car and great site for Kia information,Toddnick
toddnick is offline
post #10 of 15 (permalink) Old 10-21-2013, 05:36 PM
Muttdawg's Avatar
Quoted: 29 Post(s)
That's why I joined after I bought my Rio. I joined a paintball forum a few years back that was marker/gun specific to learn everything I could about that marker and to find answers should I have any problems. That's why I joined here too. To find the best aftermarket parts, see what ( if any) problems other people have had, and to just interact with other Kia owners.
Muttdawg is offline
Oil Change Interval MRcleanUH60M 2016+ Sorento 151 08-07-2018 06:04 PM
Transfer Case Fluid Change Bam204 2G (2003-2010) Sportage 1 09-24-2017 01:55 PM
Oil Change frequency versus type of oil used Mr Mint 2014 - 2015 Sorento Forum 9 07-04-2015 06:53 AM
Front Wheel Bearing change - a digest Temych267 1G (2001-2005) Rio 20 12-19-2011 01:49 PM
New owner - Transfering Warrenty pablo2008jedi General KIA Non-Model Specific Discussion 1 06-24-2009 12:22 PM
