Alpine amp wiring - Kia Forum
post #1 of 6 (permalink) Old 06-16-2019, 09:29 PM Thread Starter
Drives: 2017 Sportage LX
Alpine amp wiring
Hello everyone, Im trying to install Alpine KTP-445 mini amp in my base trim 2017 Sportage LX with the stock head unit,I just figure out how to connect it to speaker wire, but where should i connect these 3 wires ? Power ,remote and ground. any in put will be very appreciate .Thank you!
b101535941 is offline
post #2 of 6 (permalink) Old 06-16-2019, 09:37 PM Thread Starter
Here are pictures of wires from the head unit and amp
ID:	105706   Click image for larger version
ID:	105708   Click image for larger version
post #3 of 6 (permalink) Old 06-30-2019, 10:44 PM
Drives: Kia Sportage 2017
Quoted: 3 Post(s)
Best bet since no one has answered would be to do it the good old way: test for power with a voltage tester and speaker signal at the output of the OEM radio with a pair of cables and a speaker. You can try to call Crutchfield for support, but I think it only applies if you bought anything there. If you buy radio/speakers from them they even include all you need to do it yourself. There's something they call a mastersheet with all the info. See if they can mail it to you. Good luck and please update the thread when you have a solution.
jes1888 is online now
post #4 of 6 (permalink) Old 07-05-2019, 03:30 AM
Drives: 2017 Kia Sportage SX
Quoted: 124 Post(s)
Yup Crutchfield has a $10 make and model specific pdf guide on everything you need to know to install after market radio and or amplifier. Including info on what panels to remove and how
Sent from my SM-G955W using Tapatalk
1011555 is offline
post #5 of 6 (permalink) Old 07-05-2019, 06:27 AM
Quoted: 317 Post(s)
Metra has an adapter harness that plugs into the factory connector and provides the wires you need to install aftermarket head unit, here is the part listing
Metra Online
if you look at the wiring color code, you could use that to find the pins on the factory harness that provide the constant, and switched power, for ground use chassis.
You will need to verify using a multimeter before just going to town on it.
Crutchfield also has some information on the harness, but to get the wiring diagram with pinouts you will need to purchase that from them.
https://www.crutchfield.com/p_120707...g-Harness.html
pcguy is offline
post #6 of 6 (permalink) Old 07-05-2019, 06:29 AM
Quoted: 317 Post(s)
I would say you could easily find the constant and switched power pins on the factory harness plug by disconnecting the harness, use the pictures in the above link, and with a multimeter locate the required pins.
pcguy is offline
  Kia Forum > KIA Models > Kia Sportage Forum > 4G 2016-2018+ Sportage
