Tire noise and Kia's - Kia Forum
post #1 of 15 (permalink) Old 06-10-2019, 06:17 PM Thread Starter
Drives: 2018 SPORTAGE LX AWD
I have the AWD LX 2018 and although I think the Kia does a great job in insulating the cabin from exterior noise, better than any vehicle I've driven to date for what it's worth, the Kia produces something of a stethoscope effect for road and tire noise. The noise is noticeable and goes away to blissful nothingness when I drive over recently paved roads but seems amplified for everything else.
So that being the case, is there anything I can do? Seems like padding the interior will make it even more insulated from outside noise, but may not do a thing for tire/road noise.
106IFA is online now
post #2 of 15 (permalink) Old 06-10-2019, 06:34 PM
Quoted: 129 Post(s)
It could be the tires as well, I just recently, 2 weeks ago, replaced factory installed Nexen tires with Sumitomo HT and road noise went with the old tires. Still a bit of noise but way less and not annoying either.
I got 2014 'tage thou.
dubber09 is offline
post #3 of 15 (permalink) Old 06-10-2019, 06:46 PM
SSportage's Avatar
Drives: 2017 Sportage SX AWD
Quoted: 310 Post(s)
I think the pavement is the main factor. I've driven some expensive cars and they all had highway noise to some extent.
The Sportage OEM tires were not the best for road noise. I'll be getting new tires next summer and road noise and tread wear
will be the main thing I'll look at reading reviews, Consumer Reports, etc.
JK
SSportage is offline
post #4 of 15 (permalink) Old 06-10-2019, 08:55 PM
Drives: 2017 Kia Sportage SX
Quoted: 309 Post(s)
Dynamat is a great way to dramatically cut down on road noise, believe it or not. Downside is removing seats and carpet to do it.
pcguy is offline
post #5 of 15 (permalink) Old 06-13-2019, 08:21 PM
1saxman's Avatar
Quoted: 103 Post(s)
Its the tires. Here's something that's free and might shock you - check your cold tire pressures and set them at the value stated on the frame sticker in the driver's door jamb or in the owner's manual. You must check your tire pressures weekly for deflation and every time after anybody touches the car, like if you take it to a shop for ANY reason. Always check stone cold, first thing in the morning before the sun hits it and adjust as needed by letting air out or pumping it in. You need either a good gauge and a pump or an electric pump with a gauge like the Black & Decker 'Air Station' with the built-in digital gauge. You'll see that you have to add air frequently when the weather is getting colder and actually let air out as it warms up with the change of seasons. But you never change the tire pressure when you check them hot - it goes up when the tires heat up and it goes back down when they cool off - this is why you check them cold.
I don't know what would be different in the insulation/isolation going from a 2011 EX to a 2017 SX but the SX is much quieter. I have not ridden in a late-model KIA that I would call 'noisy' but be aware the tires can be pumped up on a new car to 50 psi instead of 35 psi or whatever is recommended, and shops always over-inflate them.
1saxman is offline
post #6 of 15 (permalink) Old 06-13-2019, 08:42 PM
Quoted: 309 Post(s)
All tires make noise to some degree or another, but there is no substitute for sound deadening materials in the floor to cut it way down.
This is exactly why the older true luxury boats were so quiet, and why they were so heavy.
Pull up the corner of the carpet on any old Cadillac or Lincoln and see the very heavy sound barrier under there.
pcguy is offline
post #7 of 15 (permalink) Old 06-13-2019, 08:46 PM
Quoted: 337 Post(s)
OEM tires typically are made from a harder rubber compound to increase tire life and mpg. Softer compounds are more expensive. The more rubber you have on the road and the softer the compound, the lower the mpg. You can get a more expensive replacement tire with a softer compound and there will be a slightly lower tire noise. That said, there are certain types of pavements where there can be a big difference in noise with a better tire. People that get wider tires than OEM as replacements, may get a slightly better ride, but road noise can be either higher or lower depending on the roads. Wider tires also get lower mpg and generally worse in ice, snow, and rain (with a couple of exceptions). I haven't replaced my tires on our Sportage yet, but I usually go for tires that have better ride quality and don't care about mpg. On my sports car, I actually changed the tires immediately after I picked it up from the dealer (since I do push it a bit in that car). I used to have a 2014 Mazda 3 with a lot of road noise and I changed the tires after about 5,000 miles. The difference on that car was fairly large. I find that road noise on our local freeways is fairly high because of a lot of concrete/grooved sections. However, that usually goes away on the asphalt surfaced interstate. Right now, I have about 17k miles on my 2017 EX, and I see no reason to change the tires since, in Vegas, the trips are fairly short and the noise is not bad at all....
rvoll is offline
post #8 of 15 (permalink) Old 06-17-2019, 12:04 AM Thread Starter
Thanks for the replies. I don't know what tires my Kia currently has (I'm too lazy to step outside) but the thing about the harder rubber compound on the OE tires makes sense.
Again, the Kia seems to be already very well padded from environmental noise. Suspension noise is good too. But when it comes to tire noise and only tire noise over certain roads, the volume just seems a bit amplified. IN fact, when you watch most test drive videos of the Kia Sportage on Youtube you can hear exactly what it is I'm talking about.
But that said, I think I can live with the noise, and even grow to like it because it makes the driving experience a little more transparent.
Over most roads that are paved well enough, the noise smooths out to nothing, so it's all good anyway.
post #9 of 15 (permalink) Old 06-17-2019, 04:22 AM
Quoted: 309 Post(s)
with tire noise there are in my experience 2 different types to it. the is the base road noise which isn't the tire, it is the rough texture to the road, and then there is actual tire specific noise, which can vary greatly, depending on the tire and it's composition / tread compound.
All tires have that baseline rumble to it, that's the road surface interacting with the tire, the tire noise adds onto to that base, sometimes it's severe and can be the noise the tread makes interacting with the road, sometimes almost a howling noise. It's hard to me to explain completely.
pcguy is offline
post #10 of 15 (permalink) Old 06-17-2019, 08:58 AM
Drives: 2011 Sorento
Having the same noise issue, I recently replaced my tires with Continental TrueContact Tour. The ride is quieter and softer.
rgnmgr is offline
  Kia Forum > KIA Models > Kia Sportage Forum > 4G 2016-2018+ Sportage
