Hard wiring dash cam in Gen 4 - Kia Forum
LinkBack Thread Tools
Old 05-19-2019, 03:54 PM Thread Starter
Drives: Sportage EX 2019
Will shortly be attempting to hard wire a dash cam into this vehicle and was wondering if somebody could enlighten me to the "using a remover" mentioned from the service/repair manual. ksportagegl. com/center_fascia_panel_repair_procedures-1209.html. Are they referring to a standard trim removal tool or is there a Kia specific tool that is used to remove the clips necessary? Quite a bit to take out in order to access the audio power connector but if somebody knows of a better place to tap into the necessary power requirements for a dash cam, I'm all ears.
Thanks in advance.
oldenglish is offline
Old 05-21-2019, 08:02 AM
number27's Avatar
Drives: 2018 Sportage EX
Quoted: 7 Post(s)
I hardwired my dash cam directly into the fuse box on the driver side door using some add-a-fuses. No need for any panel tools or anything. The cover behind the mirror pops off on its own, the wire can be tucked above the headliner without the tool, and the driver side pillar cover pops off by hand. The hardest part was determining which fuses were live all the time and which ones were triggered by the ignition. I managed to find 2 empty slots to tap into.
number27 is online now
Old 05-21-2019, 08:33 AM
Drives: 2018 Sportage SX
Quoted: 46 Post(s)
I found a large plastic pry tool useful to go behind the driver's side pillar and into the fusebox. I was hoping to use an unused power connection behind the mirror but I couldn't find enough info on it, so the fusebox way wasn't so bad.
kinglerch is offline
  Kia Forum > KIA Models > Kia Sportage Forum > 4G 2016-2018+ Sportage
New User - Need information related to squirrels eating soy based wiring - Kia Rio hklayman01 2G (2006 - 2011) Rio & Rio5 8 02-21-2018 06:32 PM
Hard wiring a dashcam Recycle1979 Kia Picanto Forum 2 04-04-2016 01:40 PM
Hard Wire Dash Cam Andrey Gurevich 3G (2012 - 2017) Rio 1 09-20-2015 12:38 PM
Question concerning Dash Kit and Wiring Harness for 2008 Sportage AcidGhost 2G (2003-2010) Sportage 0 02-25-2008 10:44 AM
