Strange driver window behavior - Kia Forum
 2Likes
  • 1 Post By pcguy
  • 1 Post By pcguy
post #1 of 6 (permalink) Old 05-14-2019, 02:53 PM Thread Starter
TexanEagleScout's Avatar
Drives: 2018 Sportage EX
Quoted: 21 Post(s)
Sometimes when my driver window is fully down and hit the "auto up" function on my switch the window will go up about 1/2 way, stop then go back down till about 3 inches of window is above the top of the door panel.
What could cause this? Has anyone else seen it before?
2018 EX w/4cyl
I have the upgrade dash display, but not the package that includes the power liftgate.
TexanEagleScout is offline
post #2 of 6 (permalink) Old 05-14-2019, 08:37 PM
Drives: 2017 Kia Sportage SX
Quoted: 319 Post(s)
That's a strange one, never seen that before. My gut instinct on that would be that it has something to do with the programming, and quite possibly a reset would clear it if it is just a software glitch. That said, if it still does it, then there must be some sort of mechanical / physical cause to it. If the vehicle is still under warranty you will want to go to the dealer to remedy the problem.
Here is the window reset procedure from the owners manual
If the power window does not operate normally, the automatic power window system must be reset as follows:
1. Turn the ignition switch to the ON position.
2. Close the driver's and passenger's window and continue pulling up the driver’s power window switch for at least 1 second after the window is completely closed.
Lou O. likes this.
pcguy is offline
post #3 of 6 (permalink) Old 05-15-2019, 06:26 AM Thread Starter
Quoted: 21 Post(s)
I'll check my owners manual. Thanks.
Are you referring to "Key On Engine Off" or "Key On Engine Running"?
post #4 of 6 (permalink) Old 05-15-2019, 08:19 PM Thread Starter
Quoted: 21 Post(s)
Here is a video clip of the strange behavior.
https://youtu.be/1NEcFDJOZNs
https://youtu.be/Xyghepg66PM
post #5 of 6 (permalink) Old 05-15-2019, 08:54 PM
Quoted: 319 Post(s)
Here is the power window reset procedure from the owners manual. Page 4-40
Lou O. likes this.
pcguy is offline
post #6 of 6 (permalink) Old 06-08-2019, 09:43 PM
Drives: 2017 Sportage SX AWD Pacific Blue with Cool Gray Interior
Quoted: 14 Post(s)
I had the exact same issue you are having with the auto-up on my '17 SX. Took to the dealer and they replaced the window motor and its working fine now. I thought it was something simpler too but turns out the entire motor assembly needed swapped. They replaced under warranty.
briantoy84 is offline
  Kia Forum > KIA Models > Kia Sportage Forum > 4G 2016-2018+ Sportage
Driver side power window issue Jamms992 Shuma & Spectra (1997-2003) 6 02-16-2019 01:58 PM
2007 KIA Rondo driver side window switch problem gtfrueh New Member Area/Introduction 0 06-16-2016 11:20 PM
Driver side window noise UrbanRondo Kia Carens & Rondo Forum 262 04-20-2010 09:17 AM
Driver side window Casper 1G (1993 - 2002) Sportage 4 09-19-2007 04:41 PM
Kia Sephia 1998/99 Driver Window LordWolF Kia Sephia Forum 2 04-03-2007 10:35 AM
