SX Oil consumption - Kia Forum
 6Likes
post #1 of 56 (permalink) Old 02-09-2019, 09:23 AM Thread Starter
ST Ken's Avatar
Drives: 2017 Sportage SX, Copper&Beige-2009 ST1300 Honda MC-Wife's: 2016 Soul+ Bright Silver
Quoted: 39 Post(s)
SX Oil consumption
My 2017 has a little over 35,000 miles on it, and I'm about due for another oil change.
I've gone just over 6,000 on the current oil.
Maybe its nothing, but I have had to add about 1/2 a quart of oil twice during this 6000 mile run.
I don't know if the winter cold season has anything to do with it.
Can't say I never added a little oil between changes before, but never this much.
Do you think I should be concerned ? Do any of you find you have to add some oil between changes ?
Love my Honda ST1300 motorcycle
ST Ken is offline
post #2 of 56 (permalink) Old 02-09-2019, 10:17 AM
Drives: 2017 Kia Sportage SX
Quoted: 317 Post(s)
mine uses no oil between changes at the same interval as you. Before panicking , what exact brand and weight of oil have you been using? regular or synthetic?
pcguy is offline
post #3 of 56 (permalink) Old 02-09-2019, 02:23 PM
Quoted: 129 Post(s)
IMHO, you should be using 0w-30, 5w-30 or 0w-40 oil in that engine and change it every 4K miles at the most.
Oil consumption is not normal, also check PCV.
dubber09 is offline
post #4 of 56 (permalink) Old 02-09-2019, 04:56 PM
1saxman's Avatar
Quoted: 105 Post(s)
Using synthetic now but at first on whatever oil the dealer was using and up to the current time, no oil consumption that can be measured on the stick. 23,000 mi. I change at 4000 to 5000 depending on how it looks. Its a little dark this time so I'll go 4000 which will probably be in March or April. Always have used 5W-30.
I don't think there's been a time I left the driveway in the car that I didn't stomp it at some point in the trip (after full operating temp) so I really don't baby it.
I use Mid-Grade gas (89/90) with Startron stabilizer/cleaner with every fill.
1 quart of oil in 6000 miles will not raise a red flag with the dealer. In the old days they wouldn't do anything under warranty unless it was using more than 1 qt/1000 mi. With me, it would be a big deal. I have not owned a vehicle since the '70s that used oil and had to have some added between changes. This corresponds with the moment I realized that my insistence on using 20W-50 racing oil in a regular car was destroying my engines. After that I have never wavered from the recommended viscosity/type.
If you have been using a heavier oil it might not be too late to go back to 5W-30.
Otherwise, there is the possibility of a leak. Do you have any oiliness anywhere around the engine? Any oil spots where it sits? I have heard of the oil lines to the turbo coming loose and leaking. Check out the oil filter area and see if its been leaking. Look at the drain plug area.
2017 Sportage SX AWD
1saxman is offline
post #5 of 56 (permalink) Old 02-09-2019, 06:19 PM
Quoted: 317 Post(s)
I would add one caveat to what you said here. There is usually a chart of allowable oil weights based on what the engine needs, and what temperature range you will be operating it in.
5W-30 is not the end all oil weight. If you never run the car in freezing temperatures, one could make the case that 10W-30 will be just fine in this application. 10W-30 has a proven track record of not shearing it's viscosity grade down as much as 5W-30 during the 5,000 or 6,000 mile drain interval. This usually applies to the folks using regular conventional oil, synthetics will have different profiles.
pcguy is offline
post #6 of 56 (permalink) Old 02-09-2019, 06:48 PM
1saxman's Avatar
Quoted: 105 Post(s)
That's true enough as far as it goes, but you don't play with the upper number which is where the trouble lies. As for me, I stick with the recommendation. It has worked perfectly for me in a number of vehicles since I wised up. The more you learn about the smaller, more powerful, dual overhead cam, multi-valve engines the more you encounter the advice to not exceed the maximum viscosity recommendation. I was reading an article in the Ford magazine twenty years ago about failures in these tight-tolerance engines from owners using a heavier oil than specified. I guess people just cannot shake the idea that a heavier oil has to be better.
1saxman is offline
post #7 of 56 (permalink) Old 02-09-2019, 07:10 PM Thread Starter
ST Ken's Avatar
Quoted: 39 Post(s)
Using synthetic Pennzoil 5w-30 Platinum
ST Ken is offline
post #8 of 56 (permalink) Old 02-09-2019, 07:16 PM Thread Starter
ST Ken's Avatar
Quoted: 39 Post(s)
Otherwise, there is the possibility of a leak. Do you have any oiliness anywhere around the engine? Any oil spots where it sits? I have heard of the oil lines to the turbo coming loose and leaking. Check out the oil filter area and see if its been leaking. Look at the drain plug area.[/QUOTE]
I saw no leaks anywhere, all around under the hood from the top, saw no leak underneath by the engine pan cover or when looking through the oil filter cover and oil drain cover openings.
ST Ken is offline
post #9 of 56 (permalink) Old 02-09-2019, 08:18 PM
Quoted: 317 Post(s)
I would keep an eye on the consumption, adding as needed to keep it topped off. Unfortunately, the amount of usage you are observing is not deemed abnormal, but does warrant keeping a close eye on the levels. Also, watch for situations where you may observe any smoke emitting from the tailpipe. That can clue you in on what the problem may be. ie: smoke at startup is a classic valve stem seal issue.
pcguy is offline
post #10 of 56 (permalink) Old 02-10-2019, 10:25 AM Thread Starter
ST Ken's Avatar
Quoted: 39 Post(s)
Is the PCV valve easy to see, find, access ?
ST Ken is offline
  Kia Forum > KIA Models > Kia Sportage Forum > 4G 2016-2018+ Sportage
Impossible avg consumption readings sunking555 Kia Niro 20 10-05-2017 10:09 AM
Instant consumption goes wild VaderCro Kia Cee'd Forum 0 03-30-2016 03:59 AM
Excessive fuel consumption Cee'd 2014 BusinessLine Christian C. Schouten Kia Cee'd Forum 8 09-15-2015 06:35 AM
Cee'd SW 1.6 crdi A/T City Fuel Consumption Darko Kia Cee'd Forum 17 07-17-2012 03:40 AM
KIA air filter not cause of high fuel consumption....figures here pistnbroke 2003-2010 Sorento Forum 35 02-18-2008 08:01 AM
