USB Charging Port (2018 LX) - Kia Forum
 6Likes
post #1 of 41 (permalink) Old 11-26-2018, 04:58 PM Thread Starter
this_is_nascar's Avatar
Drives: 2018 Kia Sportage
Quoted: 18 Post(s)
Shouldn't the USB in dash charging port be capable of charging a smartphone?
Sent from my XT1635-01 using Tapatalk
this_is_nascar is online now
post #2 of 41 (permalink) Old 11-26-2018, 06:11 PM
Drives: 2018 Sportage SX
Yes, if it is operating correctly. Verify if the cable works elsewhere, I've had that happen a time or two. If the cable is good you may need to check the fuse (I'm not sure which one) or visit the service department.
Geistemite is offline
post #3 of 41 (permalink) Old 11-26-2018, 06:18 PM
Drives: 2017 Kia Sportage
Quoted: 333 Post(s)
Yes and no. It only provides about 0.5 amp of charge. Many of the larger, newer smartphones require at least 1 amp for a decent charge and 2 amps minimum for a fast charge. If you are using Android Auto/CarPlay, that's all of the charge you will get. I wired in a 2 amp charger just for charging my smartphone using a fuse tap accessory USB plug with two outlets. I have it under the dash so all you see is the cord coming out near the built-in USB outlets.
rvoll is offline
post #4 of 41 (permalink) Old 11-27-2018, 05:08 AM Thread Starter
Quoted: 18 Post(s)
Thx. I know the cable is fine. I'll have to plug something else in there to see if anything is flowing.
post #5 of 41 (permalink) Old 11-27-2018, 09:47 AM
SSportage's Avatar
Drives: 2017 Sportage SX AWD
Quoted: 303 Post(s)
I never need to charge my phone in the SX but I think I've read on the forum that the ports only
work while the vehicle is on.
JK
SSportage is offline
post #6 of 41 (permalink) Old 11-27-2018, 11:31 AM
Drives: 2017 Sportage EX
Quoted: 43 Post(s)
The basic USB charging rate is 0.5 Amps. Only the B+ and Ground pins on the USB connector are used. The data pins are NOT used. At this charging rate, your phone may take a while to see any increase. The charger that came with your smartphone may charge at a higher rate, but it does this by communicating with the phone over the data pins. Only your phone manufacturer's charger will provide the correct data sequence to enable faster charging. Manufacturer's do this to try to force you into using their charger and not some generic brand.
Karl
2017 Sportage EX
karlh is online now
post #7 of 41 (permalink) Old 11-27-2018, 01:16 PM
Drives: '18 Sportage SX AWD
Quoted: 11 Post(s)
I have the newest iPhone, I can plug it in near low battery, use CarPlay, and have it be mostly charged at the end of most drives over 20 minutes, and fully charged after my 1 hour+ commute. I have never noticed it to be an issue. Your "solution" seems unnecessary for 99% of applications, but more power to you if you want to go all amateur electrician on a new car.
orm518 is offline
post #8 of 41 (permalink) Old 11-27-2018, 05:52 PM
1saxman's Avatar
Quoted: 99 Post(s)
Its not powerful enough to charge the newer phones quickly but given time they will charge. Basically its great for emergency phone power so at least you won't be incommunicado.
1saxman is offline
post #9 of 41 (permalink) Old 11-27-2018, 08:52 PM
Quoted: 333 Post(s)
As I understand it, this is true for USB 1.0 and 2.0. USB 3.0 has .9A downstream and 3.1 can go to 1.5A without using data lines. For whatever reason, my smartphone will not charge higher (but maintains a charge) through the car's USB port but will charge up fairly quickly on my external port with 2A.
rvoll is offline
post #10 of 41 (permalink) Old 11-27-2018, 08:59 PM
Quoted: 333 Post(s)
I don't know what you have running in the background on your iPhone, but I'm a dedicated Android user and it won't work for me. What I've done is not "amateur electrician" -- an add-a-circuit is something most people can do. However, I always put higher output extra ports on my new cars within the first month or two of ownership and on most cars, I install upgraded audio myself. I also do all of my own, up to code, wiring for my house. Installing the add-a-circuit on the Sportage is easier than on most cars and I didn't have to remove any parts of the dash except the two covers on either side of the center hump (which just easily pop out). It took me about 5 minutes total for that install.
rvoll is offline
  Kia Forum > KIA Models > Kia Sportage Forum > 4G 2016-2018+ Sportage
Not Charging shelladdison 1G (2001-2005) Rio 66 08-28-2018 07:07 AM
front usb port charging iPhone but not iPad? canadave 2016+ Sorento 9 08-17-2018 02:56 PM
UVO USB Port Charging Amperage doctoroctober 2016+ Sorento 39 11-29-2016 07:51 AM
Android Auto USB port draining battery themogul 2016+ Sorento 27 09-30-2016 05:52 PM
2001 Optima Charging issue jlgwinn 1G/2G (2001-2006) Magentis & Optima 9 04-08-2009 08:12 PM
