SX Plugs R&R - Kia Forum
 18Likes
post #1 of 96 (permalink) Old 05-11-2017, 08:46 PM Thread Starter
ST Ken's Avatar
Drives: 2017 Sportage SX, Copper&Beige-2009 ST1300 Honda MC-Wife's: 2016 Soul+ Bright Silver
Quoted: 39 Post(s)
SX Plugs R&R
In a previous post, having to replace a cracked plug or two on the SX's 2.0t did not seem unusual. I assume they are platinum.
Are the plugs on the 2.0t easy to get at ?
What plug brands and type are best to replace the originals with ?
Love my Honda ST1300 motorcycle
ST Ken is offline
post #2 of 96 (permalink) Old 05-12-2017, 04:17 AM
Drives: 2017 Kia Sportage SX
Quoted: 317 Post(s)
I am not sure what specific plug they are, I do know they are irridium. Getting to them is super easy. Just pull the plastic cover off the top of the engine, there should be 4 coil packs visible right on the top of the engine ,each one is held by a bolt. remove the coil packs and R&R plugs one at a time as not to confuse the coils. Be sure to use compressed air to blow any debris out of the plug area to prevent any dirt from falling into the cylinder when you pull each plug.
User-Name likes this.
pcguy is offline
post #3 of 96 (permalink) Old 05-13-2017, 10:47 AM
User-Name's Avatar
Drives: 2017 Sportage SX AWD-2018 Stinger GT2 AWD
Quoted: 135 Post(s)
NGK but not sure which...
User-Name is offline
post #4 of 96 (permalink) Old 05-13-2017, 02:16 PM
Quoted: 129 Post(s)
They may as well be Denso 3501, pull one out for make and p/n.
Denso plugs are good, there may not be NGK equivalent for your plugs.
Don't over tighten them or you can strip threads and crack the plug too.
dubber09 is offline
post #5 of 96 (permalink) Old 05-13-2017, 04:00 PM
Quoted: 317 Post(s)
I searched on autozone for plugs for our vehicle, 2 results come up, not sure at all if this is accurate information:
Bosch Iridium Spark Plug 9622 - Read Reviews on Bosch Iridium #9622
Denso Iridium Spark Plug 3501 - Read Reviews on Denso Iridium #3501
pcguy is offline
post #6 of 96 (permalink) Old 05-14-2017, 04:34 PM
191145's Avatar
Drives: 2017 KIA Sportage SX AWD
Quoted: 116 Post(s)
Also, do it on a cold engine.
The thing is, if you pull a plug and see a missing piece of ceramic on the tip, the problem arises of what has it done to the cylinder as it rattled around in there? You would be fortunate if it got blown out of the cylinder through the exhaust valve.
1011555 likes this.
191145 is offline
post #7 of 96 (permalink) Old 05-14-2017, 05:22 PM
Quoted: 317 Post(s)
There is no good scenario, going out the exhaust means direct impact to turbocharger vanes. That generally means time for a new turbo. If it gets past that, then it hits the Catalytic converter matrix. That's bad also.
pcguy is offline
post #8 of 96 (permalink) Old 05-15-2017, 08:37 AM Thread Starter
ST Ken's Avatar
Quoted: 39 Post(s)
Might be a good idea to replace the brand of plugs that cracked with another brand:
Bosch to Denso or Denso to Bosch
ST Ken is offline
post #9 of 96 (permalink) Old 05-15-2017, 08:46 AM
Drives: 2017 AWD Sportage SX - Black / Beige
Quoted: 626 Post(s)
Denso is what cracked in mine
Sloppy is offline
post #10 of 96 (permalink) Old 05-16-2017, 08:52 AM
Drives: 2017 Kia Sportage SX AWD and 1988 Mercedes 300CE
Quoted: 116 Post(s)
Since the plugs are going into an aluminum head, you may want to run the engine to operating temp after the new install and then go back and re-torque the plugs (same principle as installing lug nuts on aluminum wheels). The steel plug base reacts differently to increases in temp than does the aluminum head and they may relax after being heated the first time.
ddhartma is offline
  Kia Forum > KIA Models > Kia Sportage Forum > 4G 2016-2018+ Sportage
Setting spark plug gap on Denso Iridium Twin plugs? Sportage EX 3G 2011 - 2016 Sportage 12 03-21-2017 05:42 PM
17 SX Stock Plugs at 2600 miles and HKS MXL45 Comparison mad_sb 4G 2016-2018+ Sportage 23 01-09-2017 10:12 AM
Just installed new spark plugs Denso Iridiums 2012kiario5owner 3G (2012 - 2017) Rio 0 12-24-2015 03:04 PM
Spark Plugs Reno 1G/2G (2001-2006) Magentis & Optima 7 03-30-2007 11:35 AM
Spark Plugs - Platinum Tipped - standard on any models? ssssspectra06 Cerato (2003 - 2008) & Spectra5 (2004) 1 10-23-2006 01:08 PM
