Signal light staying on (mirror and rear) - Kia Forum
post #1 of 6 (permalink) Old 04-10-2019, 02:13 PM Thread Starter
Drives: 2013 Rio SX 6 speed
Hi, I’m having an issue with the signal light mirror and rear staying on. I replaced the bcm and that wasn’t the issue now I’ve been playing around with the rear signal. If I remove the rear bulb with the signal off and re install the bulb the signals will work correctly for a bit then stay on continuously.
Drizzymoto is offline
post #2 of 6 (permalink) Old 04-10-2019, 03:57 PM Thread Starter
Exclamation 2013 Rio Turn signals stay lit (Mirror & Rear)
Only the mirror and rear drivers side signal lights stay light with the ignition off. If I remove the rear bulb I can get them to turn off and fix the problem but the issue persists after a few minutes or when I flash the signal. I replaced the bcm with a new unit and this did not fix the problem
Any help is appreciated. I donít have access to a Kia dealer.
post #3 of 6 (permalink) Old 04-11-2019, 06:46 AM
Drives: 2014 Kia Rio
Hope this helps. Could be an issue with the multi switch or even in the instrument cluster.
Name:	turn signal.jpg
danelo is offline
post #4 of 6 (permalink) Old 04-11-2019, 07:08 AM
Here is why I think sometime may be a problem in the instrument cluster.
danelo is offline
post #5 of 6 (permalink) Old 04-11-2019, 04:19 PM Thread Starter
Thanks can you explain a little bit more on why you think it may be the instrument cluster? I have a new multi function switch on the way.
post #6 of 6 (permalink) Old 04-11-2019, 07:46 PM
My feeling is that something may be happening with the diodes that are towards the top of the picture. They may be allowing power to flow incorrectly. You really need to take it to a shop even if it is not the dealer. Electrical issues can be hard to track down, especially without a good amount of test equipment, and just throwing parts at the problem can get expensive.
danelo is offline
  Kia Forum > KIA Models > Kia Rio Forum > 3G (2012 - 2017) Rio
