How to? Accessory / Serpentine belt - 2.4L 4 cyl - Page 2 - Kia Forum
post #11 of 15 (permalink) Old 02-08-2012, 03:12 PM
Drives: 2006.5 KIA Optima EX, 2007 Toyota Prius II
Send a message via AIM to mickeyrom Send a message via Yahoo to mickeyrom
Originally Posted by avgwarhawk View Post
cllo, that is the serpentine belt. You got one of those.
Chains are not bullet proof either. Plastic/nylon tensioners wear. Nylon covered gears wear. The longevity of the chain is assured however after 100k things can go wrong. Much past say 125k the chain should be replaced.
I had over 150 K on my Chrysler mini van and never replaced a timing chain,or belt....whichever it had.
mickeyrom is offline
post #12 of 15 (permalink) Old 06-14-2012, 08:46 PM
Drives: 07 kia optima ex
I did my belt like this....
my post about replacing a serpentine belt 4 cyl optima
https://www.kia-forums.com/do-yoursel...tml#post426184
good luck, you'll need it!
jimrich is offline
post #13 of 15 (permalink) Old 06-08-2014, 09:48 AM
where did you find the routing diagram for the serpentine belt?? I partially remove mine, made a diagram, and now it just barely will not fit back on. I need to confirm I have the correct routing. thanks
cyclone701 is offline
post #14 of 15 (permalink) Old 06-15-2014, 08:11 AM
Drives: 2008 Kia Optima
Quoted: 44 Post(s)
turbonut is offline
post #15 of 15 (permalink) Old Today, 03:24 PM
Drives: 2006 Kia Optima 2.4L 4 Cylinder
2006 Kia Optima 2.4L Serpentine Belt Replacement
I want to thank the forum and previous contributors for giving me some insight. I looked on here last night while working on my nephew's car.
I thought we were going to have to remove the power steering hose and the upper motor mount but that was NOT NECESSARY.
You will likely need one other pair of hands to do the work, though. Gloves will help, but just be ready to scratch your hands up in the tight spaces and sharp edges everywhere.
1st, we made sure to apply the parking brake and chock the rear wheels. We jacked up the front end and used jack stands for support.
Remove the passenger side wheel and small plastic cowling between the wheel well and engine.
The previous belt had already come off and so we just had to clean out the shreds that were still tangled up.
Using the schematic, we routed the new belt around the lower pulleys and left the slack to be wrapped around the top pulley which was easier to access than the tension pulley.
The tension pulley has a 17mm bolt head that moves counterclockwise to relieve tension.
This is where you will likely need another set of hands. While I was pulling the tension pulley back, my dad used some screw drivers to ease the belt over onto the top pulley, while slowly turning it clockwise. The belt slid off and right into place.
Then just replace the cowling and wheel. That was it.
(I think that was everything, but you smarter guys feel free to let me know and I'll edit it to be more helpful of a post.)
Name:	2006 Kia Optima 2.4L Serpentine Belt Routing Diagram.jpg
El Peeko is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Old ní slow
06 Sedona 3.8L - Tighten Serpentine Belt? drbagabundo Kia Carnival & Sedona 2006+ 12 08-05-2016 08:43 AM
DIY Timing Belt - WARNING Interference Engine - Service Interval Raven1210 1G (2001-2005) Rio 104 06-04-2016 05:53 PM
Replacing Serpentine Belt Tensioner, Idlers turbonut 3G (2006.5+) Magentis & Optima 0 09-08-2015 07:50 AM
Timing Belt Rio 2001 to 2005 Raven1210 Do it Yourself 6 02-19-2012 09:34 PM
How to Replace Timing Belt Raven1210 2G (2006 - 2011) Rio & Rio5 1 05-27-2009 12:16 AM
