2008 2.0 rough idle and stalling - Kia Forum
post #1 of 8 (permalink) Old 06-30-2017, 02:30 PM Thread Starter
Drives: kia sportage 2.0 2008
My 2008 sportage 2.0 is running rough on idle. When I press the gas it immediately dies. The only code the computer receives is P0102. Is this most likely caused by the mass air flow sensor or can something else cause this error code? I replaced the spark plugs and checked all four to make sure they were firing. The sensor sells for $105 at the local parts store and at the moment I would hate to blow that if it don't fix the issue. If anyone has any ideas as to what it could be or what I need to check please let me know.
mitchc1 is offline
post #2 of 8 (permalink) Old 07-02-2017, 10:40 AM
Drives: Past 2005 Sportage LX Present 2010 Rondo EX
This can mean that: The performance of the mass air flow sensor is poor (sensor failure) or that the amount of air flow measured by the sensor is low. Check for damage to the air inlet tube (which houses the sensor), or for serious air leaks between the air box and the throttle body (loose clamps, air inlet tube disconnected etc.) If there are no signs of damage or loose connections, pick up a can of mass air flow sensor cleaner and try that first before replacing the sensor. Any autoparts store will have it available, it's good practice the clean the mass air flow sensor each time you replace the air filter.
theraymondguy is offline
post #3 of 8 (permalink) Old 07-02-2017, 10:43 AM
Of course there could be an issue with the sensor harness as well, but you'll be looking for that when disconnecting it I'm sure.
post #4 of 8 (permalink) Old 07-10-2017, 01:49 PM
chris6414's Avatar
Drives: 2006 Hyundai Santa Fe Limited 3.5, 2008 Kia Sportage 2.0, 2005 Kia Sportage 2.7
Quoted: 26 Post(s)
Most likely the sensor. Mine on my 08 died. Cleaning didn't help. Advance has them and they are good.
2008 Kia Sportage LX, 2.0, 2005 Kia Sportage EX, 2.7,
OBD Link SX Scan Tool
chris6414 is offline
post #5 of 8 (permalink) Old 07-10-2017, 02:06 PM Thread Starter
thanks for your responses. I will be buying a new MAF this week and will see if that fixes the issue.
mitchc1 is offline
post #6 of 8 (permalink) Old 07-10-2017, 03:20 PM
aquanaut20's Avatar
Quoted: 251 Post(s)
Have you considered checking its response with a LIVE DATA SCANNER, or are you content with using the parts CANNON?
... Philip
aquanaut20 is offline
post #7 of 8 (permalink) Old 07-11-2017, 11:37 AM
chris6414's Avatar
Quoted: 26 Post(s)
Mapping is fine if you know what your looking at. I mapped mine and it looked great at idle and would fluctuate after idle. TPS signal was linear. Mine had no visible damaged. It just failed.
post #8 of 8 (permalink) Old 07-31-2017, 10:57 AM Thread Starter
Smile Fixed!
The issue was a bad idle air control valve. The valve was stuck. I cleaned it with some cleaner and the car idles good. It has been running great for a few days now.
Thanks for all the replies on this issue
mitchc1 is offline
Stalling at idle fixed sbianco1 2G (1998 - 2001) Sephia 0 01-10-2017 08:29 PM
Random Misfires, idle stalling and odd transmission shifting - SOLVED Markfothebeast 1G (1993 - 2002) Sportage 0 01-10-2017 05:23 PM
random rough idle and stalling cfoust 2G (1998 - 2001) Sephia 9 09-30-2015 08:53 PM
Stalling, hesitation, rough idle JTR92207 2G (1998 - 2001) Sephia 3 01-05-2008 07:36 AM
Engine stutters heavily when idle joebob 2G (1998 - 2001) Sephia 12 06-24-2007 03:17 AM
