Clear Radio Presets - Kia Forum
post #1 of 13 (permalink) Old 05-23-2019, 07:26 PM Thread Starter
Drives: 2019 Sorento SXL AWD
Quoted: 43 Post(s)
Clear Radio Presets
On the 2019 Sorento SXL, Can you clear certain radio presets or all of them at once via a dash settings without unhooking the battery cable or fuses ?
Chicago2018 is offline
post #2 of 13 (permalink) Old 05-23-2019, 07:28 PM
steve807's Avatar
Drives: 2019 Sorento SX L (FWD)
Quoted: 43 Post(s)
I've been looking for the same thing.
Thank goodness No Turbo /// 2019 Sorento SX L V6 (FWD)
steve807 is offline
post #3 of 13 (permalink) Old 05-24-2019, 06:37 AM Thread Starter
Quoted: 43 Post(s)
I actually just want to cycle through the media formats using the button on the wheel.
Whenever I am on one of the radio modes and change the station to one I want as default, I cycle through again and that station is not the default for that mode. How can this be set?
If it can, I won't care about other presets I don't use anymore.
Does that make sense ?
Thank you
post #4 of 13 (permalink) Old 05-24-2019, 12:16 PM
steve807's Avatar
Quoted: 43 Post(s)
My frustration is the many duplicates I have in my memorized list of stations. Don't know how I did that. Fat fingered something probably.
steve807 is offline
post #5 of 13 (permalink) Old 05-24-2019, 12:37 PM
Drives: me nutz and a Sorento SX-V6 2016
Quoted: 43 Post(s)
You can reset it
There's a small access hole in the upper right hand corner of the head unit. Use a toothpick.
Section 1, page 6 in your multimedia manual.
Kronyx is online now
post #6 of 13 (permalink) Old 05-24-2019, 01:21 PM Thread Starter
Quoted: 43 Post(s)
Originally Posted by Kronyx View Post
You can reset it
Hello Kronyx. I looked in the (US) manual and saw this...RESET Resets the system settings. (Preset radio channels and other data will not be deleted). Is there a different place to reset the presets as you mentioned?
post #7 of 13 (permalink) Old 05-24-2019, 02:19 PM
Quoted: 43 Post(s)
I didn't know that, well just unplug your battery for 2 minutes it will do the trick !
post #8 of 13 (permalink) Old 05-24-2019, 02:25 PM
Drives: 2016 Kia Sorento SX
Quoted: 32 Post(s)
I'm pretty certain I've not lost my presets which changing a battery or disconnecting it for other reasons.. Radio might have an internal backup or its saves them in a place that doesn't require power.
rhall1690 is offline
post #9 of 13 (permalink) Old 05-24-2019, 02:51 PM
Quoted: 43 Post(s)
Did you check the config in the cluster menu ? I know you can choose with input you want but don't know if you can select the channels ?
post #10 of 13 (permalink) Old 05-24-2019, 04:54 PM Thread Starter
Quoted: 43 Post(s)
I searched and found this on another Kia blog. I'll try it if all applies and others might try it as well.
Press Setup button on dash.
Choose System Info icon on touchscreen.
Choose Default on the left side of the touchscreen
Press Default button on bottom of touchscreen
That should reset all your custom stereo settings, including radio presets, back to factory default.
How do I delete radio presets in 2018 Kia Optima SX MikeP 4G (2011+) Optima 2 02-18-2019 04:28 PM
2017 Sportage ex radio and presets spotty 4G 2016-2018+ Sportage 14 06-07-2016 12:23 PM
Help with steering wheel radio presets? MikDee 2014 - 2015 Sorento Forum 9 09-04-2015 01:41 AM
Deleting radio presets mistermayy Kia Magentis & Optima Forum 2 04-26-2009 10:50 AM
