2019 V6 oil level - Kia Forum
post #1 of 14 (permalink) Old 04-20-2019, 09:07 AM Thread Starter
Drives: 2019 Sorento SXL
Quoted: 4 Post(s)
2019 V6 oil level
Notice the factory fill and after 2 oil changes the oil level is only half way on the dip stick. Anyone notice this?
Wondering if there is a spec issue or problem with my stick. The level never changes so I haven’t bothers to add any, plus I don’t know if filling to the full mark will cause it to be overfilled.
2011SX is offline
post #2 of 14 (permalink) Old 04-20-2019, 10:03 AM
steve807's Avatar
Drives: 2019 Sorento SX L (FWD)
Quoted: 34 Post(s)
Who did the oil changes ?
The quick change places often set a dial and pump in the 4.5 quarts...
Thank goodness No Turbo /// 2019 Sorento SX L V6 (FWD)
steve807 is offline
post #3 of 14 (permalink) Old 04-20-2019, 10:44 AM
Drives: 2014 Sorento EX
Quoted: 19 Post(s)
I discovered that the level will appear to be slightly low if the dipstick is just pulled out and level is observed. Apparently after operation, the tightly sealed top of the dipstick will not let oil back in bottom of the tube. So, always "double dip" when checking the V-6 oil level. That said, it only results in a slightly lower than actual level. I can't think of any reason a "wrong" dipstick would be your engine. It sounds as though the person changing the oil is not allowing for the amount the filter takes or just doing what steve807 said. I would go someplace else to have it changed next time and see what happens. I always have mine done at the dealer. After getting home I double check it and it is always right on the proper mark. Nothing wrong with checking it as mentioned above and adding required amount. One thing, be sure to use exactly the same type, weight and brand oil as was put in at the change.
Watnext is offline
post #4 of 14 (permalink) Old 04-20-2019, 11:08 AM Thread Starter
Quoted: 4 Post(s)
Thanks for the quick response and suggestions. Both changes have been done at a Kia dealer. As far as checking levels I’ve always been one to check it after 15min or sitting overnight. On first pull the level is way down at the bottom, second or more pulls show the level halfway.
2011SX is offline
post #5 of 14 (permalink) Old 04-20-2019, 11:25 AM
Drives: 2011 Forte SX 2.4L (thankfully MPI) A/T 131K miles
Quoted: 253 Post(s)
Are you certain the surface is level where you're checking the oil? Take a look at the amount of oil listed on the Kia paperwork, and also check your owner's manual to see what the spec amount of oil is for an oil change including filter replacement.
kiaguy002 is offline
post #6 of 14 (permalink) Old 04-20-2019, 12:24 PM
rejesterd's Avatar
Quoted: 141 Post(s)
Take your measurement in the morning after the car has sat overnight. If it's only 1/2 full then, add 1/2 a quart. If it's 3/4 full, I would just leave it where it is. Don't go over the full mark. Better to be slightly under than over.
rejesterd is online now
post #7 of 14 (permalink) Old 04-20-2019, 02:15 PM
Drives: 2019 Sorento EX V6
Quoted: 280 Post(s)
It takes more than the previous engine with the filter on top. They are probably under filling.
scosgt is offline
post #8 of 14 (permalink) Old 04-20-2019, 07:22 PM
Drives: 2016 Sorento SXL
Quoted: 172 Post(s)
Yeah, but what kind of nitwit doesn't check the stick itself after an oil change? That kind of error should be discovered before the hood slams.
ecanderson is offline
post #9 of 14 (permalink) Old 04-20-2019, 08:48 PM Thread Starter
Quoted: 4 Post(s)
Thanks everyone. I’ve checked it in 3 different garages and I’d say they are all level. I’ve got worried the first time I checked after a thousand miles or so and notice it half way. Thought it was eating oil lol.
Just find it odd that it was half full from factory too.
Checked the paperwork too. Both times only show 5w30 oil kit 11.50/unit, but nothing about how many quarts.
Sounds like it’s just mine if no one else has noticed it. Going to have a different dealer change it next when we are back at the beach. Will update everyone then if it’s the same after.
2011SX is offline
post #10 of 14 (permalink) Old 04-20-2019, 08:51 PM
rejesterd's Avatar
Quoted: 141 Post(s)
Originally Posted by 2011SX View Post
Thanks everyone. Iíve checked it in 3 different garages and Iíd say they are all level. Iíve got worried the first time I checked after a thousand miles or so and notice it half way. Thought it was eating oil lol.
Sounds like itís just mine if no one else has noticed it. Going to have a different dealer change it next when we are back at the beach. Will update everyone then if itís the same after.
If I drove to the garage, my level would be just above halfway. Not an accurate measurement unless the car has been cold for a good 4 hours.
Any news on the 2019 Kia Forte5 release date and details? al_roethlisberger Kia Forte/Cerato (TD) and Koup Discussion Forum 5 03-31-2019 06:34 AM
2019 Kia Rio updates and release date known? al_roethlisberger 3G (2012 - 2017) Rio 8 12-08-2018 11:21 AM
Traded my 2019 soul for a 2019 soul Butch73 Kia Soul Forum 2 11-15-2018 06:12 AM
Transmission Fluid Level Question rms 1G (1993 - 2002) Sportage 3 05-14-2007 01:02 PM
