Fuel pump precautions - Page 2 - Kia Forum
 1Likes
post #11 of 15 (permalink) Old 04-17-2019, 12:30 PM
Lou O.'s Avatar
Quoted: 27 Post(s)
The electric fuel pumps located in the gas tank are cooled by the fuel in the tank.
Yes it is true that the pump can overheat and seize if uncovered enough.
Even though you may have a gallon or two left, it may not be touching the pump.
Modern blow molded plastic gas tanks are very contorted to fit into and around tight spaces.
I'm a child of the oil embargo years (70's) and rarely let my tank get below half.....need to
be on top of the Zombie Apocalypse you know!
Lou O. is offline
post #12 of 15 (permalink) Old 04-17-2019, 01:03 PM
rejesterd's Avatar
Quoted: 141 Post(s)
For the pump to overheat due to low fuel, you would have to run it way down (like past zero on your "miles remaining" gauge) and then keep it there for months by putting in a quart of fuel when you go to fill up every time. Nobody does that, which is partly why this design came about. An unexposed fuel pump that, for 99% of the time you drive it, is being cooled by sitting in a pool of fuel will typically last longer than an exposed pump that requires a separate cooling component.. and it's cheaper to manufacture, so it helps keep the overall price low. Kia isn't the only one who does this.
I regularly run my tank down to near empty.. I've done this on many cars I've owned and never had to replace a fuel pump.
rejesterd is offline
post #13 of 15 (permalink) Old 04-17-2019, 01:34 PM
number27's Avatar
Drives: 2018 Sportage EX
Quoted: 7 Post(s)
I know I have a different car, but when mine says it’s dead empty, there still seems to be about 10L left in the tank (fill from “dead empty” is about 53L but listed tank size in the manual is 62L). Is it common to have such a large “reserve” amount left in the tank or is my gauge miscalibrated?
number27 is offline
post #14 of 15 (permalink) Old 04-17-2019, 08:45 PM
Drives: 2019 Sorento LX AWD 2.4L w/ Convenience Package, 2018 Mitsubishi Outlander SE-AWC
Quoted: 168 Post(s)
It is normal because people are dumb. So the manufacturers give people an “empty” indicator when they still can do something about it instead of at a true empty when dummies would end up stranded.
SoothingDave is offline
post #15 of 15 (permalink) Old 04-18-2019, 05:12 PM
Drives: Sorento LX V6 2018
Quoted: 83 Post(s)
I remember leaving my car parked overnight at the gas station, getting up early to go be with it, to get my allotted 8 gallons of gas on my allotted day. I too have become paranoid about anything less than 1/2 a tank because of it.
tom4416 is offline
04 Optima 4 Cylinder Fuel Pump Problem Gregspost 1G/2G (2001-2006) Magentis & Optima 2 07-18-2017 03:57 PM
Replace fuel pump as pump or complete module? JensenHealey Kia Carnival & Sedona (2002 - 2005) 1 01-06-2017 09:10 AM
2006 sedona fuel filter ecorn Kia Carnival & Sedona 2006+ 5 07-20-2011 07:29 AM
fuel pump priming issue vitaminK 2G (1998 - 2001) Sephia 5 01-27-2011 07:23 AM
Fuel pump, filter & injector maintenance. cmhj2000 Do it Yourself 1 08-28-2009 03:43 PM
