Ethanol 15 gas for my 2017 Kia Sorento turbo? - Kia Forum
 2Likes
  • 1 Post By Lou O.
  • 1 Post By 2019Sorento
post #1 of 8 (permalink) Old 04-13-2019, 11:00 AM Thread Starter
jhw59's Avatar
Drives: 2017 Sorento EX
Quoted: 10 Post(s)
It appears that if this grade becomes available this summer, I should avoid using it in my Sorento. It may, in fact, void the warranty as well. Any knowledge on this?
jhw59 is offline
post #2 of 8 (permalink) Old 04-13-2019, 12:35 PM
Drives: 2016 Sorento SXL
Quoted: 172 Post(s)
There are parts of the U.S. where it is nearly impossible to avoid the summer 10% blend due to EPA issues with local smog. However, I doubt you'll see E15 widely distributed in the DC area in spite of the waivers allowing its production and distribution. FAR too many vehicle manufacturers have argued against its use in their non-E85 vehicles. I hadn't noticed that Virginia had taken any new action along these lines. Citation?
As to warranty issues, check your manual. It may well state that "Kia recommends that customers do not use fuel with an ethanol content exceeding 10 percent". One could imagine (though haven't yet seen it) a situation where E15 was the lowest level available, leaving Kia in a bit of a bind regarding warranty questions.
ecanderson is online now
post #3 of 8 (permalink) Old 04-13-2019, 04:34 PM
Lou O.'s Avatar
Quoted: 14 Post(s)
Very wise to stay away for anything higher than E10.....Ethanol is very hard on an engine unless hardened for it...
jetech00001 likes this.
Lou O. is offline
post #4 of 8 (permalink) Old 04-15-2019, 11:04 PM
rejesterd's Avatar
Quoted: 141 Post(s)
https://ethanolrfa.org/2017/11/rfa-a...2018-vehicles/
The 2019 Sorento manual approves E15, as do 90% of all manufacturers now. Back in 2017, it was 81%. Kia didn't update their manuals at that time, so it's unclear for your vehicle.. but unless they made some significant changes since then, E15 appears to be ok. Especially if you don't plan on keeping the car for a ridiculous amount of time.
I'm also coming from the boating world, where ethanol is discussed all the time, and has been ever since E10 became widely available. After about 17 years of working on my father's outboard engine and my own (whose manuals recommend not using any amount of ethanol), it's clear to me that E10 hasn't caused any issues. Unless you let that fuel sit in your tank for months, it's not going to be a problem imo.
rejesterd is offline
post #5 of 8 (permalink) Old 04-16-2019, 06:40 AM
Drives: 2019 Sorento SX AWD
Quoted: 67 Post(s)
I agree that most manufacturers have changed their designs to use materials more resistant to attack from higher alcohol content in the fuel. I wouldn't be that paranoid about E15, but keep in mind that your gas mileage drops a little more compared to E10 and a noticeable amount compared to ethanol-free gas.
Cheers!
rejesterd likes this.
2013 Sorento EX V6 AWD
2019 Sorento SX V6 AWD
2017 Dodge Charger Scatpack
2019Sorento is offline
post #6 of 8 (permalink) Old 04-16-2019, 11:08 AM
Drives: Sorento 2016 SX V6
Quoted: 6 Post(s)
This brings up sort of an interesting question. Are the EPA mileage estimates based on pure gasoline? Probably. On the other hand, in most areas you can't avoid at least 10% ethanol. No wonder so many people have trouble matching the estimates. The deck is loaded (if not leaded - sorry!)
Larry
lproulx is offline
post #7 of 8 (permalink) Old 04-24-2019, 09:47 AM Thread Starter
jhw59's Avatar
Quoted: 10 Post(s)
Thanks for the replies. I may call KIA directly and get the official response.
jhw59 is offline
post #8 of 8 (permalink) Old 04-25-2019, 12:32 AM
Quoted: 172 Post(s)
Larry
The dice may be loaded (or the deck stacked, to avoid a mixed metaphor), but not very significantly in this case. Assuming a full 10% (E10) blend, and most pumps say "up to"...
90% x 100% (using straight gas as a baseline of 100) = 90
10% x 70% (ethanol is ~70% energy density of same volume of gas) = 7
Resulting E10 blend gives you about 97% the energy density of E0 gas.
Where it sucks loudly is at E85 blends.
15% x 100% = 15
85% x 70% = 59.5
Resulting E85 blend gives you about 75% the energy density of E0 gas, so you'd better not be paying more than 75% the price at the pump for E85, assuming you've got a vehicle that can use it.
four 17 inch OEM from a 2017 sorento for sale paragod22 2016+ Sorento 0 11-15-2017 09:15 AM
2017 Sorento 3.3 V6 shudder/Vibration at idle Pulsar7377 2016+ Sorento 32 11-07-2017 12:59 PM
Accident: 2017 Sorento rear ended. j_vayne 2016+ Sorento 101 10-07-2017 12:18 PM
New Forum User! 2017 Sorento EX bpeterson93 2016+ Sorento 13 08-13-2017 03:06 PM
Close to Purchasing 2017 EX Turbo mrwiseguy85 2016+ Sorento 13 10-13-2016 10:57 PM
