2019 Sorento V6 Oil Change Guide - Kia Forum
 21Likes
post #1 of 74 (permalink) Old 02-19-2019, 08:14 AM Thread Starter
Drives: 2019 Sorento
Quoted: 14 Post(s)
Hi Everyone
I'm looking for an online tutorial on how to do an oil change on a 2019 V6 Sorento. I know the engine design has changed a little bit for 2019 (V6) and I'd love to see how to complete the oil change via a manual or how to (especially which filter to use, I know there's been some confusion on type).
Thanks in advance.
jimmystiff is offline
post #2 of 74 (permalink) Old 02-19-2019, 08:42 AM
BrianC302's Avatar
Drives: 2016 Sorento EX V6
Quoted: 193 Post(s)
Originally Posted by jimmystiff View Post
Hi Everyone
Thanks in advance.
You would be better off having the dealer do it while in warranty for piece of mind. Sure, you can document it and in theory should be OK.... but if you need to make a claim on the engine you will be sweating it out!
I can tell you the splash guard is a PITA to remove as there are so many fasteners.
steve807 likes this.
BrianC302 is offline
post #3 of 74 (permalink) Old 02-19-2019, 01:12 PM
Drives: 2016 Sorento SX 2.0 Turbo
Quoted: 275 Post(s)
I don't find the splash guard a PITA to remove and I also don't have a lot of faith in the workmanship of the dealership.
The first oil change there was the last. 4 of the 17 fasteners were missing when I did the second oil change.
Receipts for a factory filter, the correct API rated oil and a date and mileage log is all you need. No theory involved.
For added measure I take a picture of the odometer, the products and the vehicle on ramps. The images provide a date and time stamp.
hand-filer is offline
post #4 of 74 (permalink) Old 02-19-2019, 02:08 PM
BrianC302's Avatar
Quoted: 193 Post(s)
As far as oil changes going, I don't know how you don't feel the splash guard is a PITA. 17 fasteners is about double any car I have had before but whatever. It takes longer to mess around with the tray than it would to change the oil.
I used to document my oil changes like you described on my Saabaru but when we got our Audi I was afraid I may have issues (which we did.... BIG ONES). I don't trust the dealers/car companies to do the right thing when they are going to cover many thousands of dollars in repairs. Yes, in theory they have to but they can make it VERY difficult for you. It would be easy to get lazy/lose a receipt or pictures over a 100,000 mile period.
If they deny your claim, you may win in the end after getting a lawyer but for me having the oil changed at the dealer is cheap insurance. My dealer only charges $45 for an oil change and tire rotation with a coupon. For me it is a no brainer but I appreciate some live far from dealers and it is a royal PITA so doing it at home saves a lot of time/aggravation.
post #5 of 74 (permalink) Old 02-19-2019, 07:56 PM
Drives: 2019 Sorento SX AWD
Quoted: 66 Post(s)
I posted the procedure a while ago (search my posts). It is fairly painless if you've got a nutdriver or small impact gun to remove all the belly pan bolts. I think it took me 15 minutes from start to finish with ramps and a creeper.
Best,
Pretender likes this.
2013 Sorento EX V6 AWD
2019 Sorento SX V6 AWD
2017 Dodge Charger Scatpack
2019Sorento is offline
post #6 of 74 (permalink) Old 02-20-2019, 07:15 AM Thread Starter
Quoted: 14 Post(s)
The idea that an OEM can deny warranty claims because a private shop or owner does his or her own work is not correct, including oil changes.
post #7 of 74 (permalink) Old 02-20-2019, 07:30 AM Thread Starter
Quoted: 14 Post(s)
Thanks, I agree, I don't trust the dealer to do any quality work, I'll only go to them for warranty work. Agreed on simply documenting any work and there will be no issue with warranty.
post #8 of 74 (permalink) Old 02-20-2019, 07:30 AM Thread Starter
Quoted: 14 Post(s)
Thanks, I found the thread where you describe what you did. Appreciate the reply.
post #9 of 74 (permalink) Old 02-20-2019, 12:10 PM
BrianC302's Avatar
Quoted: 193 Post(s)
Are you really that confident? You saying there will be no issue with the warranty doesn't mean anything to KIA lol. Who are you? Sure, you may win in the end (after a HUGE inconvenience and possible legal fees) but for me there is more piece of mind having the dealer service the car while in warranty (at least oil changes and ideally coolant and transmission fluid if applicable too). If they do something wrong while servicing the car, you aggressively deal with it from multiple angles and I doubt you ever have a problem again.
A quick Google search would bring up several stories similar to the one below and indicate that you a rolling the dice..... I don't care what you think and what is "right". In the real world, things may not go smoothly and that is why I have all fluids changed by the dealer and on time/under mileage so is something goes wrong, there is no BS!
And when you say you don't trust the dealer to do any quality work but you would trust them to warranty work? That sounds really odd to me as the warranty work is usually way more involved than a simple oil change.
https://www.reddit.com/r/legaladvice...o_charge_6700/
Kia is denying warranty, trying to charge $6700
2015 optima with about 36k miles. Engine seized shortly after a DIY oil change(Jan 20). After being towed to the dealer they "diagnosed" bearing failure (I put that in quotes because all the guy did was take 2 minutes and put a wrench on the crankshaft pulley and try to rotate it). Since I didn't have oil receipts on me they were going to charge $6700 to replace the engine. So I decided to fight it. Got in touch with kia consumer affairs, which went nowhere. Apparently they refuse to acknowledge the magnuson-moss warranty act, whereby the MUST PROVE that I caused the failure. After sending some complaints out, I was contacted by Megan in the escalations dept. She began working with the dealership on the issue. 1st excuse to deny warranty: lack of maintentance receipts. Apparently they don't understand that a lack of receipts does not mean a lack of maintenance. So I was able to scrounge up a few and send them to the service manager at the dealership. More on this later.
2nd excuse: there must be oil sludge in the engine. Sales manager pulled the valve cover and sent in pictures. In his words, there is no sign of a lack of maintenance, the engine is free of sludge and carbon build up. It appears brand new. Oops kia, that didn't work. So they are trying this next one.
3rd excuse: use of non-oem fluids and filter. I use amsoil 5w20, receipts verify this. Owner's manual specifies 5w20 oil with a rating of API SM and/or ILSAC GF-4. Amsoil holds an API SN and ILSAC GF-5 rating, both superior to oem. The filter is purolator one, rated for 10k miles, same spring relief pressure as oem, high density synthetic blend material, and is made by MANN who makes the oem filter! Oops again kia.
I have been able to find three more oil receipts, bringing the total to five. The change interval is 7500 miles. Including the last change (six) I am well within the interval specified in the manual.
At this point I'm ready to buy a complete engine for $1700 and put it in myself. This puts me $5000 under their quote, which is absurd. If I have to do that I'll take them to small claims court for the maximum penalty in Florida. Right now all they've offered to do is waive the labor costs, still putting me at around $3800. They have still failed to prove I am at fault for the failure (because I'm not) and therefore have no right to deny warranty.
Any thoughts on additional recourse? I have been without a car for over a month now that I am still making payments on.
Update: this keeps getting views and votes so I guess I should provide a status report. After multiple emails to the vp of warranty affairs with no response, I replaced the engine myself for $1500. 14k miles later, there are no issues, and the replacement motor (canadian) runs stronger and gets better mileage.
Oddly enough kia issued a recall for this very issue but conveniently stopped with the 2014 model year. I never miss an opportunity to bash the company and their product publicly.
post #10 of 74 (permalink) Old 02-20-2019, 12:38 PM
Drives: 2018 Sorento LX 2.4 FWD; 2009 Borrego LX V6 RWD
Quoted: 29 Post(s)
It's easy to cut out holes on that cover.
chuckwalla is offline
2019 Sorento is 1.6 inches longer? Subneil 2016+ Sorento 1 12-26-2018 10:12 AM
2019 Sorento EX: Good price? martex 2016+ Sorento 8 08-14-2018 08:38 AM
2019 Sorento Traffic rmdennis 2016+ Sorento 1 07-20-2018 09:51 AM
2017 Sorento dealership oil change climax102 Kia Carnival & Sedona 2015+ 11 04-26-2018 03:54 PM
