Powered Subwoofer Installed - Kia Forum
 5Likes
  • 3 Post By chuckwalla
  • 1 Post By chuckwalla
post #1 of 9 (permalink) Old 01-19-2019, 07:30 PM Thread Starter
Drives: 2018 Sorento LX 2.4 FWD; 2009 Borrego LX V6 RWD
Quoted: 30 Post(s)
Installed a Rockville 8" subwoofer SS8P. Because of the heater vents under both front seats, ended up placing under the left rear seat which had just enough clearance.
Cut a slit and slid the power cable next to the factory wiring loom thru the firewall.
Drilled a hole on the positive terminal battery cover to access the battery post.
The unit has auto power on feature when hooked up via high level speaker wire, so just spliced the rear speaker wires from the driver and passenger rocker panels and didn't have to remove the head unit for the remote power wire.
The speaker wire colors are as follows. They are twisted pairs and are thicker than others and thus easy to identify.
Rear Left+ = YELLOW
Rear Left - = BLACK
Rear Right+ = GREEN
Rear Right- = ORANGE
Mounted the the remote control below the climate system using a double-sided tape.
Connected the ground wire to the back left bolt of the rear seat.
It was an all day job, but the improved sound quality is well worth the effort. Fills the cabin nicely with bass even when listening at relatively low volume which is my preference.
ID:	103916   Click image for larger version
ID:	103918   Click image for larger version
ID:	103920   Click image for larger version
ID:	103922   Click image for larger version
lowatts, Stephan26 and Al Hart like this.
chuckwalla is offline
post #2 of 9 (permalink) Old 01-19-2019, 08:13 PM
Stephan26's Avatar
Drives: Kia Sorento EX+ V6 2018
Quoted: 8 Post(s)
Nice! Was actually looking at that very same sub. So worth it? So you hooked up power to the battery directly, ground to the rear seat bolt. then left and right speaker connection and that is it? Simple enough. Will have to wait a bit...until spring at least but will definitively be on my to-do list. thanks.
...and all that could have been.
Stephan26 is offline
post #3 of 9 (permalink) Old 01-24-2019, 04:51 AM
Drives: 2019 Black Sorento SX V6 w/SX Touring Pkg.
Quoted: 5 Post(s)
Where are the speaker wires that you tapped into located?
pfontainejr is offline
post #4 of 9 (permalink) Old 01-24-2019, 06:56 PM
Quoted: 5 Post(s)
May i ask where the speaker wires you tapped into located in the pictures?
post #5 of 9 (permalink) Old 01-24-2019, 09:12 PM
Drives: 2018 Sorento LX V6 AWD Conv. Pkg. Tech Pkg.
Quoted: 69 Post(s)
Thanks Chuck!
I have the same audio system as you, and I find it mediocre. Is simply adding the sub enough to make the sound very good? How about when you crank it up?
JohnH123 is offline
post #6 of 9 (permalink) Old 01-24-2019, 09:26 PM Thread Starter
Quoted: 30 Post(s)
The wires are tapped from the driver and front passenger door sills. Pull off the plastic cover, and you'll see a bundle of wires. You will then need to slice open the electrical tape covering the wires to access them. Pic #4 is the driver side, and pic #5 is the passenger side.
Stephan26 likes this.
post #7 of 9 (permalink) Old 01-24-2019, 09:37 PM Thread Starter
Quoted: 30 Post(s)
Originally Posted by JohnH123 View Post
Thanks Chuck!
You'll definitely hear the lows that were missing before, but it won't make your system sound like a high end unit with components. That said, I am very happy with the results.
I usually don't go past volume level 20, and thus my frequency, input gain and bass boost levels are adjusted accordingly.
JohnH123 likes this.
post #8 of 9 (permalink) Old 01-31-2019, 08:35 PM
Drives: Sorento LX 2013
pics of the sub needed
The older I get, the faster I was!
whoosh is offline
post #9 of 9 (permalink) Old 02-02-2019, 08:21 PM
Drives: 2017 Sorento EX V6
Quoted: 14 Post(s)
Thanks for the post with pictures. That spot in the firewall is where I was going to try for when I install mine, glad to see it works well. Hoping for some warmer weather soon to get it done, a sunny day with temps above 40 should be good enough.
lowatts is offline
Mudguards with OEM step rails installed?? teamarctic9289 2014 - 2015 Sorento Forum 1 01-20-2018 11:17 AM
Powered Subwoofer Install ImStricken06 2016+ Sorento 31 03-22-2017 01:39 PM
Inoperative Subwoofer BadDog42 Kia Carnival & Sedona 2006+ 0 06-24-2016 05:46 PM
