Initial New Sorento Gas Mileage - AWFUL - Kia Forum
 11Likes
post #1 of 54 (permalink) Old 11-21-2018, 07:33 PM Thread Starter
Drives: 2019 Sorento SXL AWD Silver Ext/Black Int
Quoted: 3 Post(s)
Hi Guys
New to the forum. Just bought a new 2019 SXL after tons of research and chose it over the Lexus, Honda, Toyota, Hyundai, and Buick. Love the vehicle so far. I've only driven 40 miles locally and have lost 3/8 of a tank already which is unbelievably poor to me. The info on the dash (I reset after driving the first 25 miles) is not moving over 15...I'm doing all local driving (not start/stop either just local roads doing 35/40). Driving in Comfort mode. No A/C on. Not towing or having heavy loads.
I know it's early in my ownership. I called the dealer and they told me the computer takes a few fillups to build a baseline to report accurate average MPG. Make sense, but I went the the computer only after the fuel gauge dropped so quickly. So, not worried about the computer, but more about how much fuel I've burned since with only 40 miles driven. With 5/8 of a tank left - vehicle says 220 till empty.
Does anyone attribute this to it just being a new vehicle? Couldn't find anything on the internet with gas mileage being a big problem with the Sorentos.
skillset is offline
post #2 of 54 (permalink) Old 11-21-2018, 07:37 PM
Drives: 2018 Sorento
Quoted: 22 Post(s)
For my 2018 v6, on a full tank, I'll get about 450km. Most of it is highway driving, but in heavy Toronto 401 traffic both ways.
Sent from my SM-N920W8 using Tapatalk
l2iceman is offline
post #3 of 54 (permalink) Old 11-21-2018, 09:01 PM Thread Starter
Quoted: 3 Post(s)
I2iceman - that seems low too, don't you think? Assuming an 18.8 gallon gas tank, 450km is 24 km per gallon or converting to gallons is 15 miles per gallon. Supposed to get 19/24. Forgot to mention mine is AWD.
skillset is offline
post #4 of 54 (permalink) Old 11-21-2018, 09:06 PM
Quoted: 22 Post(s)
Well I don't drive it down to the wire, so going by 18.8 gallon tank isn't accurate unless you drive from Full until the car dies (even once the light comes on you still have quite a bit to go).
I'm thinking I should get another 50 to 100 km.
The main drive is in heavy traffic, so with that considered, I think I'm probably in line haha
l2iceman is offline
post #5 of 54 (permalink) Old 11-21-2018, 09:49 PM
Drives: 2019 Sorento EX V6
Quoted: 287 Post(s)
I was about to post on this subject.
My 2016 SX got no better than 16 in combined driving. The MPG readout was always around 2 MPG high,
My 2019 EX V6 got 15.7 on the prior fillup, the meter was spot on.
Filled up tonight, the actual computed MPG was 18.8, the meter read 19.8
So I think they have improved the calculations! Very happy about that, 1 MPG differential is well within accepted parameters.
I have around 900 miles on the car. Since the last fillup I pumped out the original oil and put in Mobil One full synthetic. I know I am making this up, but the acceleration and MPG are better!
The dealer says they use syn blend on the free oil changes, no one knows what the factory uses, but I would bet it is not synthetic.
Since the filter is now underneath, I will have to bring it in for oil changes, but then I will do the same thing - use my vacuum pump to remove the blend and install Mobil One. Much happier with it.
I think between the Mobil One and the 8 speed tranny, the MPG has improved significantly. This is in NY Thanksgiving time traffic, plenty of it. Some highway, lots of stop and go. I keep it in COMFORT mode.
scosgt is offline
post #6 of 54 (permalink) Old 11-21-2018, 10:50 PM
Drives: 2019 Sorento EX AWD
Quoted: 42 Post(s)
Send a message via MSN to GeorgiaBoy
It does seem a little thirsty but I'd suggest giving it a tank or two and maybe a road trip and see what it does. After all it is new!
I can tell you that 3 months & 3400+ miles in, my 19 EX AWD is about right on the mpg money, 18-20 city, 22 combined & 24-25 highway. In fact, we just completed a 600+ mi run south on highways & I75 through GA & FL and averaged 24.9 & 25.3 @ 70-80 mph (depended on traffic & driver!). It'll be interesting to see what it does going back north cause you know we'll be going up hill!😜😜
And, I should note that all my mpg numbers are "real world" mileage (i.e., # of miles/# of gallons) not trip comp. calculations. In fact, over all fill ups I've found the trip comp. to read any where from 0 to 10% high, so I'd say it averages about 5% high.
Anyway, good luck & hope everyone has happy thanksgiving!
GeorgiaBoy is online now
post #7 of 54 (permalink) Old 11-22-2018, 12:10 AM
Quoted: 43 Post(s)
Did you disregard the computer and check the mileage after filling up, then after filling up again (figuring for the gallons replaced)? That would give you a check on the computer as well. You might do this a few times to account for the extra filled in your tank after the first click/shut-off of the pump.
Chicago2018 is offline
post #8 of 54 (permalink) Old 11-22-2018, 06:32 AM
Drives: 2016 Sorento SX V6, Regency Red, Built in Georgia March 16, 2016 - Bought it April 28th, 2016
Quoted: 176 Post(s)
Not surprised, new vehicle engine break in, drivetrain break in, tire …, you get it. Also winter fuel blend is really hard on fuel economy.
Frankly, the Sorento V6 in top trims are not known for their good fuel economy, everything else makes up for it.
Danno001 is offline
post #9 of 54 (permalink) Old 11-22-2018, 06:50 AM Thread Starter
Quoted: 3 Post(s)
Scosgt - appreciate the detailed reply. I guess nearly 19 combined is 5 off from the rated, so, geez, not that great! Ultimately, I guess that's not horrible but a lot below what I thought I was going to get! Anyway, car's going to be driven mostly by wife locally so I suspect I'll be more like in the 15 range...maybe less Good tip on the Synthetic oil - seems liked you dumped the original oil right after your purchase.
GeorgiaBoy - thanks for sharing southern numbers! Good to hear your getting decent numbers - hopefully it will do much better on the highway - haven't take it out highway. My niece is at UGA - great area!
Agree I need to give it a few tanks, but was just pretty alarmed it burned 3/8 of a tank going just a few miles. I haven't yet had a fill up and I haven't really been paying that much attention to the computer MPG. It drives amazing and, as far as I can tell, there's nothing sounding wrong with the engine - it's quiet as hell.
Happy Thanksgiving
skillset is offline
post #10 of 54 (permalink) Old 11-22-2018, 07:05 AM
Drives: 2019 Sorento SX AWD
Quoted: 67 Post(s)
I just drove our 2019 SX AWD from Virginia to CT and had actual mileage of 26.5mpg on the highway with a few bouts of bumper to bumper traffic. Around town, we were seeing 20-21mpg. It's only got 800 miles on it now.
Edit: Also, that's with winter tires! I bought an extra set of rims with Pirelli Scorpion snow tires and put them on at about 200 miles on the clock. Also, when I get back to VA in a few days, I plan to dump the factory oil and refill with Mobil1 synthetic oil.
Cheers!
scosgt likes this.
2013 Sorento EX V6 AWD
2019 Sorento SX V6 AWD
2017 Dodge Charger Scatpack
2019Sorento is offline
2014 Sorento SX Gas Mileage jaunt 2014 - 2015 Sorento Forum 14 01-27-2016 04:00 PM
Kia Sorento Crankshaft Pulley Bolt Shawn 2003-2010 Sorento Forum 17 05-20-2011 09:07 AM
3.8V6 2007 Sorento Swim Philippines 4 08-06-2008 01:45 AM
Whats the highest mileage on a Sorento we know of? Black Sorento 2003-2010 Sorento Forum 0 08-29-2006 11:26 AM
Attention KIA Sorento 4x4 Drivers: Help Needed desert_rat 2003-2010 Sorento Forum 2 06-24-2006 09:33 AM
