Got so hot I tried to open my 2019 SXL windows at work to cool off the inside but could not without turning on the engine. In the key driven older car all I had to do was turn the key to auxiliary mode and the radio would come on also allowing me to open the windows. This does not seem to work in that mode with the push button start.
Is it possible ? Thank you
Thank you. I will try that to open the windows tomorrow when I stop for gas.
Found something else......
I just looked in the manual again and saw (on the SXL) the button below the A/C is the A/C off button. I have always pushed the A/C for "on" and saw the light, then pushed it again for "off" and the light went out. What am I missing, or does it work both ways? Thank you again !
