DIY - Positioning Lights as DRLs - Kia Forum
 48Likes
post #1 of 82 (permalink) Old 03-09-2017, 11:36 AM Thread Starter
josuet's Avatar
Drives: 2016 Sorento EX 2.0T AWD
Quoted: 713 Post(s)
My positioning lights are now officially running as DRLs.
After 2 full weeks of testing period, I built and installed the second module (Passenger side). I must warn you all, you need lots of patience and skills in electronics to complete below project.
This installation is for Canadian Sorentos, although it can be easily adapted to the US version (See comments at the bottom). Before going into the beef, let me define a few specs:
  1. DRL Reduced OEM Voltage (High Beam) : 2.32 Volts
  2. High Beam Voltage: 14.5 Volts
  3. Parking Lights Voltage (Input of LED controller): ~13 volts.
  4. Positioning Lights (Output of LED controller): 12.5 Volts and 60 miliAmps
  5. High Beams ALWAYS turn on along with the Low Beams.
  6. Low Beams ALWAYS turn on the Parking Lights (Positioning LED eyebrows and tail lights)
  7. LED controller outputs 4 wires, 2 for LED eyebrow (Red/Black) and 2 for 3-led yellow parking light (Yellow/Blue)
Since I didn't want to run any cable into the headlamp housing, I had to boost the OEM DRL voltage (2.3 volts) to 12.5 volts while running on DRL mode but also disable my circuit when Parking lights (Only or LB or HB+LB ) were ON, so LED eyebrows would not received voltage from 2 separate sources simultaneously.
Something I realized after my initial exploration, the LED controller monitors the current going through it, meaning that the current returning from the led strip MUST come through the LED controller. If the current flows back across another ground circuit, LED EYEBROWS WILL NOT TURN ON. When parking lights are off (No input voltage), LED controller opens both lines to the LED strip.
Taking all that into account, I came up with this circuit:
Materials:
2 DC to DC Voltage Booster (https://www.amazon.ca/dp/B011EBSKK0/...528420_TE_dp_1)
2 Voltage Regulator LM7812 (https://www.amazon.com/L7812CV-LM781.../dp/B00O072KB6)
4 Diodes (50v 1 Amp)
2 Double Pole mini relay 12vDC 5Amp (G5V-2-DC12: Omron : Double Pole Double Throw 2A 12 Volt: Electromechanical)
1 Dual Perforated Mini PBC board (https://www.radioshack.com/products/dual-mini-board)
2 JST-PH (2mm) Jumper 4-Wire Assembly (JST-PH (2mm) Jumper 4-Wire Assembly (15cm wire) in Canada Robotix)
Cable 28-30 AWG (Multiple Colors)
Shrinking Tube according to the AWG
How it works:
Relay bridges simultaneously both poles (Positive and negative from High Beam) when is not receiving signal from the parking lights (+) and opens the circuit when parking lights are ON. Voltage regulator ensures the input voltage at the booster does not surpass 12 Volts. Booster increases the voltage from 2.32 to 12.5 (When on DRL only) and from 12 to 12.5 Volts (If raise the high beams while lights are off ). Diodes prevent current from flowing back into any of the the sources through the positive wire.
Given that I had to place my module in between the LED controller and the Load (LED strip), I used a very similar connector type (Male/Female) as the OEM connector. Note you must use the 4 wires of the connectors, 2 for LED eyebrows and 2 for 3-LED yellow parking light (These 2 go straight from controller to LED strip harness, they DO NOT enter the boosting module)
Female connector goes into the led controller and Male goes to the LED strip connector. It can all be removed without leaving any trace and even if the module breaks, it will keep the circuit between the LED controller and the LED strip working as OEM.
Installation:
1) Preparation: Remove the low and high beam dust caps. Remove the Low and High beam bulbs. Remove the fuse box cover (Driver Side) and the Coolant container (Passenger side).
2) Disconnect the headlamp harness connector. Lower-right pin (Housing socket) is empty, but there is a rubber cap tucked from behind, stick a thin Allen Key to push the rubber cap out of the slot into the headlight housing.
3) Using a wire, fish the Parking Light Signal cable (From module) through the newly created pin slot by sticking the wire through the open pin slot and out through the Low Beam bulb opening. Twist the cable around the pin (Parking Lights +) next to it. Place harness connector back in.
4)Remove the socket cap from the High beam socket. Run the DRL voltage cables (From module) through the socket cap and hook them both to each terminal (Positive and Ground) of the High Beam socket.
5) Stick your hand (Palm up) into the headlight housing and disconnect the LED strip harness from the LED controller. Plug in the Female harness (from module) into the LED controller and the Male harness (from module) to the LED strip harness.
Other/US Models
There is good and bad news.
Bad: There is no voltage source inside the headlamp housing to power the LED strips, thus you will need to run an ACC wire from the fuse box into the housing through one of the unused pins of the Headlamp harness connector.
Good: Less complicated circuit.
Warning: DO NOT let any tool/part lingering over the engine or somewhere around the engine compartment. If something falls down it's nearly impossible to bring it back.
josuet is offline
post #2 of 82 (permalink) Old 03-09-2017, 11:42 AM Thread Starter
josuet's Avatar
Quoted: 713 Post(s)
More Pics
Flickering is not visible to the human eye. Turn on CC.
josuet is offline
post #3 of 82 (permalink) Old 03-09-2017, 03:09 PM
ztorque's Avatar
Drives: 2016 SORENTO LX / 2010 KIA SOUL ! / 1995 NISSAN 300ZX TWIN TURBO
Quoted: 75 Post(s)
Man nice work I wish you lived closer lol.
Sent from my iPhone using Tapatalk
josuet and Coolwhip like this.
ztorque is offline
post #4 of 82 (permalink) Old 03-09-2017, 03:45 PM
Coolwhip's Avatar
Drives: 2016 Sorento sx 2.0T
Quoted: 92 Post(s)
Get in line ztorque
josuet, dardsa and ztorque like this.
Coolwhip is offline
post #5 of 82 (permalink) Old 03-09-2017, 04:43 PM
CrazyBiker's Avatar
Drives: 17' Sorento SXL V6 AWD, 14' Mazda6 GT w/ Tech, 16 Aprilia Tuono V4 Factory, 14' BMW S1000R
Quoted: 362 Post(s)
How much if you start making them for us?
CrazyBiker is online now
post #6 of 82 (permalink) Old 03-09-2017, 04:58 PM
Coolwhip's Avatar
Quoted: 92 Post(s)
That's some crazy figuring out,out of my comfort zone.You da man.If you mass produce them as plug and play I'm in
Coolwhip is offline
post #7 of 82 (permalink) Old 03-09-2017, 04:58 PM Thread Starter
josuet's Avatar
Quoted: 713 Post(s)
Sent you a PM.
josuet is offline
post #8 of 82 (permalink) Old 03-09-2017, 05:02 PM Thread Starter
josuet's Avatar
Quoted: 713 Post(s)
I can ship them ready to install but since we aren't tapping nor splicing any cable, there is a part (Bullet 3, 4 and 5) you would need to do yourself, unless you want me to install them
josuet is offline
post #9 of 82 (permalink) Old 03-09-2017, 05:12 PM
Coolwhip's Avatar
Quoted: 92 Post(s)
That circuit board,would it be exposed to the elements or incased in something or inside something?
dardsa likes this.
Coolwhip is offline
post #10 of 82 (permalink) Old 03-09-2017, 05:21 PM
Coolwhip's Avatar
Quoted: 92 Post(s)
That circuit board,would it be exposed to the elements or incased in something or inside something?I think your north of me.I vacation in the north end at the cottage in the summer.Durability test till the summer and if they pass count me in.May even drop in for upgrade as to not [email protected] it up.Deal?
dardsa likes this.
Coolwhip is offline
Convert positioning lights to DRL mletchworth Kia Carnival & Sedona 2015+ 23 03-15-2019 10:49 AM
Positioning lights "burnt out" 76camaro 2014 - 2015 Sorento Forum 17 12-03-2016 04:12 PM
Brightness of Positioning lights / Loudness of safety systems shabx 2016+ Sorento 2 10-09-2016 12:11 PM
2001 Spectra Interior/Tail lights turn on/off when they like. Linake Shuma & Spectra (1997-2003) 2 12-31-2011 05:25 PM
Problem with Daytime Running Lights - Canadian Sorento Jason_S 2003-2010 Sorento Forum 5 07-20-2008 07:13 PM
