LED light bar with cargo basket - Kia Forum
 39Likes
LinkBack Thread Tools
Old 02-12-2017, 12:03 PM Thread Starter
stupidchicken03's Avatar
Drives: 2017 SWP LX Sorento - 2005 big turbo Subaru STI - 2018 Subaru Crosstrek
Quoted: 36 Post(s)
So my plan for this was to mount up a Yakima Loadwarrior with a 32" LED light bar in the front of it. Im going to replace the black wind deflector with a clear plexiglass one ill make so the light bar is protected and still usable. Im also using weatherpack connectors from the harness to the light bar, so I can easily remove the basket/light combo and set it aside for storage or use it on another one of our vehicles.
This is the universal kit I bought and used for the wire harness ($11.95 when I bought it): https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Im pretty OCD when it comes to wiring. If its possible to not see the wires, im going to try. I also want it to look OEM/clean if you do see it.
So here is where I mounted the relay (green circle) and ran the positive/negative cable connections
1_zpsaksacwe0 by Thomas Hibben, on Flickr
Here is a look with all the caps/covers back on. The green lines are where I ran the harness. The power supply to the lights runs up the drivers side fender under all the trim, the other goes under the fuse box and through the firewall with the main harness of the car.
2_zpscu7jlesw by Thomas Hibben, on Flickr
Coolwhip likes this.
stupidchicken03 is offline
Old 02-12-2017, 12:04 PM Thread Starter
Quoted: 36 Post(s)
Next few pics are trim pieces I removed to run the wires under them
3_zpsjgxq1bm9 by Thomas Hibben, on Flickr
4_zpskwskafyi by Thomas Hibben, on Flickr
5_zps63waosec by Thomas Hibben, on Flickr
6_zpsmsfr2o34 by Thomas Hibben, on Flickr
Old 02-12-2017, 12:05 PM Thread Starter
Quoted: 36 Post(s)
I was able to unbolt the first 3 bolts of the OEM roof rails. This gave me enough wiggle room to feed the harness under it and out the other side.
7_zpsgo9asqra by Thomas Hibben, on Flickr
8_zpsaceslrfu by Thomas Hibben, on Flickr
As of right now, the harness is zip tied to the OEM roof rail as I ran out of time yesterday. The switch is in the cabin just hanging out behind the lower fuse panel for now till i decide where I want to permanently mount it.
Today Im going to mount the LED light bar to the basket. Once that's done, I can mount the basket to the car and determine cable length from the LED bar and car harness before trimming and installing the weatherpack connectors.
These are the mounts I used for the LED bar to the Yakima basket ($14.99 when I bought them): https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Im going to have to modify them a bit for a better/tighter fit. One of those, you get what you pay for type thing, but they work well enough.
This is a rough pic of test mounting the LED bar to the basket last night.
9_zps44tnen7f by Thomas Hibben, on Flickr
Ill post/update as more gets finished with the project. Hoping to have it all done by mid week, including the new plexi cut out. We're heading to our cabin next Friday and would love to test this out in the woods at night!
dardsa, Coolwhip, dsatwork and 1 others like this.
Old 02-12-2017, 12:14 PM
Drives: 2016 Kia Sorento LX V6 AWD
Quoted: 24 Post(s)
WOW nice work
dsatwork is offline
Old 02-12-2017, 09:42 PM Thread Starter
Quoted: 36 Post(s)
Thank you.
Got the LED bar mounted to the basket today. Ran out of time to do the weatherpack connectors.
Started a 1965 GT Fastback project this afternoon. So there's more of my time gone lol.
Old 02-13-2017, 10:46 PM
ImStricken06's Avatar
Drives: 2016 Sorento, 2013 Santa Fe
Quoted: 136 Post(s)
i'd use thicker gauge wire than that harness you have. use the distance/gauge chart. for that distance, you'd need at least 10gauge to supply enough amps so to not over-heat the wire
No information posted shall create or express any guarantee of any particular result. For entertainment use only!
ImStricken06 is offline
Old 02-14-2017, 09:01 AM Thread Starter
Quoted: 36 Post(s)
Got the wind deflector cut out of plexi yesterday
IMG_20170213_164224_zpsvlofv6cx by Thomas Hibben, on Flickr
wrapped some black panel trim around the edges
IMG_20170213_172649_1_zps5nibtzyb by Thomas Hibben, on Flickr
Installed on the basket
IMG_20170213_172832_zpsv146pchr by Thomas Hibben, on Flickr
IMG_20170213_172847_zpsb6r4hpcn by Thomas Hibben, on Flickr
MCKSHNL and Coolwhip like this.
Old 02-14-2017, 09:03 AM Thread Starter
Quoted: 36 Post(s)
Did a quick test of the lights on the car last night
light off vs light on
MCKSHNL likes this.
Old 02-14-2017, 09:06 AM
josuet's Avatar
Drives: 2016 Sorento EX 2.0T AWD
Quoted: 713 Post(s)
Not to be a bad omen but, but I think the Plexiglas's angle will create a significant amount of light deflection....did you try it already?
josuet is offline
Old 02-14-2017, 09:13 AM Thread Starter
Quoted: 36 Post(s)
Yea I was kinda thinking about that too before I put it on.
The main focus of the light seems pretty high in front of my garage, but since its so close from the front of the car, I cant tell if its being deflected up or just from sitting so high up on the car.
We're heading to our cabin this weekend, so I should be able to test it out in the middle of no where without any other lights around to get a more accurate test. The LED bar is mainly for off-road use.. so whenever we're out at the cabin or driving down a road late at night with no other cars around.
I certainly wouldnt use this driving around the highway and blind everyone around me lol.
KIA Fog Light LED Bulbs! Plug & Play Install! Upgrade your lights! Diode Dynamics Diode Dynamics 39 06-21-2018 05:28 PM
Cargo area light problem sassington 2014 - 2015 Sorento Forum 9 02-01-2018 04:36 PM
Turning off traction control and turn on 4wd lock sohokia 2011 - 2013 (XM) Sorento Forum 10 10-26-2017 02:57 PM
Inexpensive cargo light option Yorkanuck Kia Carens & Rondo Forum 11 02-01-2010 07:14 AM
Light bulbs for 06 Sedona Repsolal Kia Carnival & Sedona 2006+ 2 12-17-2008 10:44 AM
