-   2016+ Sorento (https://www.kia-forums.com/2016-sorento/)
-   -   0 - 60 / 0 - 100 (https://www.kia-forums.com/2016-sorento/232537-0-60-0-100-a.html)
elighawi 03-21-2016 03:39 AM
0 - 60 / 0 - 100
My V6 AWD with ESC off / Sport mode do 1 - 100 KMH in 9.2s - 9.4s
Shouldn't be faster?
What yours doing?
PLP 03-21-2016 07:21 AM
Automatic or manual?
If manual, then numbers can vary a lot due to different shifting techniques.
See here:
http://www.zeroto60times.com/vehicle...-60-mph-times/
elighawi 03-21-2016 07:42 AM
Automatic trans.
i thought should be around 8 - 8.5 sec
Over 9 sec for V6 engine it's a bit slow, no?
My old sportage 2.4l 2011 AWD auto was doing 9.6 / 10 sec
SXdriver 03-21-2016 07:50 AM
Not sure but looking at consumer reports I think they got 7.2sec 0-60 time for the V6. They get their cars right from a dealer so that number should be good. You should turn off the ESC and give it some brake torque before launching it. Have you tried manual shift mode? I haven't seen 0-100km numbers but they will always be a bit longer than 0-60mph. I'm also wondering if your car has a different transmission, final drive ratio or engine tuning that would result in a different result than a North American car,
What I have seen is that the v6 is faster 0-60 than the turbo but they are virtually the same from 30-50 and 50-70 times. It's a heavy vehicle and it's not going to be super fast from a dead stop.
TitaniumSXL 03-21-2016 08:01 AM
Even Consumer Reports got 7.4 sec. 0-60mph for V6 AWD
Car & Driver reported 7.2 sec. 0-60mph w/ 2016 Sorento V6 AWD. I recall a 6.9 sec. time reported by some tester for FWD. All domestic Sorento's are 6-speed automatics.
elighawi 03-21-2016 08:10 AM
will give a try with manual shift mode and brake torque, but don't think will make a difference as it will shift up automatically even if you don't manually.
ESC was off
It is indeed heavy vehicle, not expecting it to be super fast but not over 9 sec for sure
100 kmh = 62.2 mph difference is 2.2 mph a half of second maybe
If consumer reports got 7.2 i should get no more than 8 sec
Michael Koch-Schulte 05-16-2016 11:04 AM
I read somewhere that Consumers Reports does a rolling start on those tests. I use an OBD 2 box (remove the fuse panel on the left side of the steering wheel and just plug it in) and the Torque App on my Note 2 phone on my EX v6 (17" tires, 18" might do better?) and usually can get it in the mid to high 8 seconds range from a dead start while holding it back a little with the brakes. I used "normal" mode and automatic transmission mode. "Sport" mode was actually slower for some reason. Quarter mile is around 16-17 seconds depending on the wind. :)
~m
majic12 05-16-2016 11:30 AM
My 0-60 is around 13 seconds...trying to save gas lol
kobi411 05-16-2016 11:33 AM
wow i thought the the 2016 would be quicker.. my 2012 is a smidge faster
Sorento2016 05-16-2016 06:18 PM
Never timed our 2.4L LX - would likely need a calendar instead of a stopwatch.
