0455 code - Kia Forum
 1Likes
  • 1 Post By bobdec
post #1 of 3 (permalink) Old 01-02-2019, 09:41 AM Thread Starter
Drives: 2014 Sorento LX
Quoted: 28 Post(s)
0455 code
So I have a 0455 code on my '14 Sorento. Tightened the gas cap, and after 30 ish miles the light was still on. Took off and put gas cap back on again. Disconnected battery for a minute or two, then went for a short drive and light came back on after 5-6 miles. Bought a new gas cap, light is still on. So I'm thinking it's not the gas cap. What are your suggestions of where to look first? I'm not looking to just throw parts at it to fix it, just asking of what to look for. I've got some time since my tags/emissions are not due until August. Is this a common issue on Sorento's? And if so, what usually fixes it? Thanks in advance for the replies.
2014 Sorento LX is offline
post #2 of 3 (permalink) Old 01-03-2019, 03:20 PM
Drives: Sorento SX FWD 2015
Quoted: 25 Post(s)
Noticed there's no responses to your post. My guess is because there is really no "common issue" of evap failures on the Sorentos. I've see some scattered posts on failures, some disappeared, others were the gas cap. The code P0455 (big leak in evap system) is thrown when the ECM tests the EVAP system. It closes the fuel tank air vent (CCV solinoid) and opens the vacuum source (PCSV) solenoid to the intake manifold). At that time the ECM expects the vacuum sensor (FTPS) in the tank to read an increasing vacuum. Fixing a problem in this area is not complex, but can be a PITA, it requires inspecting and pulling hoses and attaching a vacuum source to the components of the evap system. If no leaks on vacuum tester it can then be the sensor. The following url will give you an idea of how the evap sys works.
Kia Sorento: Evaporative Emission Control System - Emission Control System - Kia Sorento XM 2011-2019 Service Manual .
LMP likes this.
I'm Bob, 2015 Sorento SX , 2007 GMC Envoy (tuned) , 1994 Camaro Z28 (modified/custom tuned)
bobdec is offline
post #3 of 3 (permalink) Old 05-19-2019, 11:56 PM
Drives: 2014 Kia Sorento 3.3 V6
Not sure if you found the issue or not since this was posted four months ago but check the charcoal canister(vapor canister) under the car. My wife apparently ran something over and it tore the cover and put two holes in the canister. That set off the same trouble code. It's an expensive fix, I highly suggest Rock Auto for the part as they were cheaper than any of the car parts stores. Took about 30 minutes to replace.
Steel4pens is offline
2008 Mass Air Flow Sensor Code P0102 KiaGlock&Jacoby 2003-2010 Sorento Forum 1 08-11-2017 12:31 PM
2011 Forte SX P0017 Code Impaqt Kia Forte/Cerato (TD) and Koup Discussion Forum 0 08-17-2016 11:52 PM
Key code format jakejack 2016+ Sorento 4 05-17-2016 04:30 PM
Just bought A Code Reader! Actron Autoscanner CP9670 2012kiario5owner 3G (2012 - 2017) Rio 6 12-25-2015 12:56 AM
P0133 code and cracked exhaust manifold slydog 2G (1998 - 2001) Sephia 7 07-26-2010 10:39 AM
