2014 Sorento SX Gas Mileage - Kia Forum
post #1 of 15 (permalink) Old 01-20-2016, 02:42 PM Thread Starter
Hello,
I'm new to the forum and to Kia's in general. I very recently purchased a 2014 Sorento SX with 29K, still under warranty. (V6 GDI). Seems in mint condition, regularly serviced.
We're on Vancouver Island so the climate is around 6-10 degrees C at the moment. I park in a parking garage overnight so it's warm. No hills to and from work. My commute is 70% 50kph, 30% 90kph on the way to work (10k one way). When I first got it I was driving pretty aggressively but now driving as modestly as I can. 2 problems:
1. On start in the morning, it idles at 1500 RPM for at least a minute and sounds a little rough to my ears. I don't usually wait for it to drop to something more reasonable. Is that normal?
2. No matter how I drive I seem to always get 16 l/100 km which is only 14.7 mpg. Is this in the realm of reasonable? Seems pretty terrible to me.
The dealer is very elusive about gas mileage and won't give me a straight answer.
Thanks any advice / experience you can share!
jaunt is offline
post #2 of 15 (permalink) Old 01-20-2016, 02:50 PM
Location: Outside Fort Myers, Fl. Where the Panthers and Alligators roam
Drives: 2014 Kia Sorento SXL 2WD, 1961 Triunph TR4 Roadster
Quoted: 289 Post(s)
The initial rough idling is due to the GDI engine that mimics a little a diesel engine. The slight chatter should go away after a minute or so.
The gas consumption seems to be a little high, but the engine has hardly a chance to get warm during this 10k long drive.
It is much colder where I live (North Western Wisconsin), and I get on cold days between 19 - 20 mpg.
Hudsoner is offline
post #3 of 15 (permalink) Old 01-20-2016, 03:05 PM
Drives: '15 SX, '19 Stinger GT2 AWD
Quoted: 279 Post(s)
Seems low but as stated that's not much of a test. Certainly don't wait for it to "warm up" before driving as that doesn't help.
Suggest you reset the MPG stats and take a nice long drive one afternoon, 100km or more, and see what it says. I average about 17.5, I don't drive gently and Atlanta is not very flat. On a highway trip I'll get low-to-mid 20's, best is 24.
eflyguy is offline
post #4 of 15 (permalink) Old 01-20-2016, 03:18 PM
Wahoobie's Avatar
Drives: '14 Sorento SX V6 (2WD)
Quoted: 54 Post(s)
Originally Posted by eflyguy View Post
...Certainly don't wait for it to "warm up" before driving as that doesn't help....
Yeah, I expect if you are starting it up, then going back inside for a bit, that it would tank the MPG calc on the computer since the entire time you are getting 0 MPG (granted at very light load/RPM). That suggestion of resetting the computer calc once the drive starts is a great one!
-- Brighter Position Light / Halo DRL (
Wahoobie is offline
post #5 of 15 (permalink) Old 01-20-2016, 03:34 PM Thread Starter
Very interesting, thanks Hudsoner, eflyguy, and Wahoobie.
Just a note that for my regular commute I start going immediately in the morning without waiting. I was only waiting to see how fast the RPM would come down to diagnose if that was separate issue.
I will try the reset + 100KM drive test. As well, I will check again when I refill today as last time I reset the trip A so will be able to see how many KM I traveled vs how many litres I put back in to fill. This will also indicate if the trip computer is inaccurate.
jaunt is offline
post #6 of 15 (permalink) Old 01-20-2016, 08:06 PM
Quoted: 279 Post(s)
The trip computer is as accurate as the odometer. You should take a look at the Fuelly web site and associated app..
Here's my Sorento: Sorento II (Kia Sorento) | Fuelly
eflyguy is offline
post #7 of 15 (permalink) Old 01-21-2016, 01:16 PM Thread Starter
eflyguy, you are right, the trip computer was accurate. I filled up to day and calculated mileage to 16.1 l/100km which is 14.61 MPG.
Atlanta looks to be similar temperatures and it looks as if you've never got below 16?
I guess next question is if there's anything I can try to improve the situation? Apparently the fuel filter needs to be replaced at 36K or something like that. Perhaps I could do it early. I read somewhere carbon might build up but not sure if that would be the issue.
P.S. what octane do you use?
jaunt is offline
post #8 of 15 (permalink) Old 01-21-2016, 01:47 PM
MikDee's Avatar
Quoted: 172 Post(s)
Try a different brand of gas! I now use BP, or Gulf, Reg. 87 oct. (across the street from each other) 15 miles away on the border of Jersey, because of the price, BP discount & convenience. The Sorento seems to run best, with the best mileage on either of these.
Up here in the rural tri-state area I avg. 20-22mpg around town, but I've seen 17-18mpg, with other brands.
I used to use BP PlUS 89 oct. for the best power, & mileage, but recently it seems to run worse then regular? I don't know what the hell they're doing to the gas? I still think it's (Stale, reserve surplus gas, because it suddenly got cheap awhile ago!). I don't think the oil companies did this out of "the goodness of their heart". It makes sense, because now they can keep pumping to fill the reserves, and "Then once the smoke clears, slowly raise the price all over again".
MikDee is offline
post #9 of 15 (permalink) Old 01-22-2016, 01:56 PM
Quoted: 279 Post(s)
I use 87 octane exclusively, from Kroger or Costco (both Top Tier rated.) This is more for price and convenience than quality, but when I have to buy elsewhere like on a road trip, I only use top-tier stations.
I did run 89 once after reading about it here, but didn't really notice any difference, and forgot to take a note of it to see if the mpg was any better.
I can feel a difference in gas quality on my bikes, and I'm often buying from remote stations where they don't turn it over very often, but never had bad gas in a car - at least, never enough to cause bad running or poor mpg.
eflyguy is offline
post #10 of 15 (permalink) Old 01-22-2016, 11:36 PM
MikDee's Avatar
Quoted: 172 Post(s)
Okay, Awhile ago I stopped buying BP 89, because the car began to run worse, instead of better, and lost a couple of mpg as well? I have been only using BP 87 since. I get the best power, & mileage on this over other brands too. Well, my lady went to fill up yesterday, and accidently got BP 89 instead. Next, she called me on the cell to say she just got gas, BP 89, and the car was "chugging"? I said, "I told you not to use 89 anymore, just 87", she forgot. Because the 89 wasn't the same anymore there? Next, we both noticed the gas mileage went from 20mpg, to 18mpg!
"Chugging" is the term she uses to describe that the car seems to be working harder then normal,,, lol, but I've definitely noticed this effect myself.
MikDee is offline
Towing Capacity of 2014 Sorento ex v6 awd blitzilla 2014 - 2015 Sorento Forum 7 05-22-2017 09:12 AM
2014 Sorento HID install, lights shut off jimbot11 2014 - 2015 Sorento Forum 6 03-23-2017 12:38 PM
2014 Sorento burning oil ? redlobster 2014 - 2015 Sorento Forum 24 10-10-2016 01:44 PM
2014 Sorento with Panoramic SunRoof Diane 2014 - 2015 Sorento Forum 9 08-12-2016 10:44 AM
2014 sorento lx Katzkin leather seats just installed Dug Doodle 2014 - 2015 Sorento Forum 12 07-28-2015 09:56 AM
